Question about Emerson LC320EM9 32 in. LCD HDTV
My Emmerson 32 inch lcd tv has the problem of; the set up menu will pop up and the sound will roll down to zero. the remote will not control either of these and not operate the tv at all. I can manually turn of the set up menu,and raise the volume but in a few seconds it will do it again, sometimes the setup menu and the volume display with flicker alternately on and off.
  • Emerson Master
  • 19,396 Answers
Hi.
From description you have a faulty key control board. Do the steps below before replacing the part.
First remove batteries from remote, to ensure that the remote is not causing the problem.
As second step contact Funai that builds Emersons and ask a firmware update (if available) for this model, then perform the firmware update. Their number is 1 800 605 8457, or the number listed on the user manual.
If no update is available, test and replace the key controller board. The board is tested reading Ohms with multimeter on board contacts.
Here the part for the model listed: Emerson BA8AF0F01022-3 Key Control Board
Here all parts for the model listed : Emerson LC320EM9
Posted on Jul 14, 2010
  • 3 more comments
  • wbdrey Jul 14, 2010
    I have pulled the batteries out, and put fresh ones in it. The tv behaves the same with or with out batteries in the remote.
  • Ginko
    Ginko Jul 14, 2010
    In that case the problem is likely the key controller board. Contact first the manufacturer and follow the indications given on my previous comment.
  • wbdrey Jul 15, 2010
    I ordered the part.We will see what happens when I get it. thanks.
  • wbdrey Jul 20, 2010
    The little brown truck brought the part and it worked like a charm, thank you.
  • Ginko
    Ginko Jul 21, 2010
    Hi.
    You are welcome. Nice to know it's fixed!
    All the best.
    Ginko.
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
How do you reboot and unlock tv
Hello
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Mar 28, 2011 | RCA L32HD31 32 in. LCD HDTV
Hello! I bought a LG 32-inch LCD (32 inch )
My best advice would be to call out your LG service repair engineer, it is most likely the current software in the TV is of an older version & will need to be re-programmed which an engineer should be able to check. This should cure the menu problem.
Mar 21, 2010 | LG Televison & Video
Volume goes down to 0 and the menu goes on and off.
A bad connection on the small signal board may be the problem! Have a Tech check this connection, it may be to tight due to the heat shrink tube. Have them peel it back to reduce the strain! Should work then!
Sep 11, 2009 | Philips 32PFL6704D 32 in. LCD TV
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
I have a 32 inch Proscan LCD tv. Is there any way
I found this solution on the PROSCAN website. www.oncorpus.com.In the customer support section, under manuals for you model of television. I hope this information helps you with your problem. Press MENU on the front panel or on the remote control and then use the up and down arrows to select the AUDIO menu.Press the enter button to enter the function.
1. Use the up and down arrows to select what you want to adjust in the AUDIO menu.
2. Press ENTER button to select it and then use the right and left arrows to adjust
3. When you are satisfied with your adjustment, press MENU to exit the main menu.
Audio Mode.
Feb 26, 2009 | Proscan 32LA30Q Television
Emerson LC320EM9 32 in. LCD HDTV Logo
173 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
