Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Clear View Plus 12-Amp Vacuum
How does one replace the main roller drive belt (The larger one, not the rubber chain looking belt)
Many Sincere Thanks,
J.R.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjf
Posted on Sep 30, 2010
Rollers don't turn and pump doesn't put out any shampoo or rinse water
You need to replace the Pump belt and the roller brush belt. You can get both belts and view the manual which has instructions here:
Bissell Proheat Replacement Belts and Manual
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
I would like to see how to change the belts on the bissell 8910 pro heat I have looked for hours now. I saw the book but it mentions and shows nothing on how to replace them. Help please.
turn the vacuum over so that the bottom side is facing you, remove the 4 screws on each side using a Philips screw drive set the screws and the brush cover aside.
- pull brush straight out and you will see the gray rubber band.
-replace the new drive belt over the motor pulley and the floor brush.
-replace the floor brush by lining up with the slots and rotate untill centered , install the cover and screws . done your back in action.
Hope this helps.
Sep 05, 2009 | Bissell 8910 ProHeat Clear View Upright...
Scrub roller wont spin
pull the bottom cover off and replace the drive belt for the brush drum, if the belt is ok then replace the drive motor for the brushes.
Jul 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
My bissell proheat 12 amp will not spray water on to the carpet,nor will the hand tools spray water?
The water is pumped via the belt that drives the pump. Remove the belt pump on the left side of the unit using a screwdriver and prying upward in the slot in the rear of the belt cover. The belt cover has holes in it. Check to make sure the belt is not broken. If it is replace, about $3-4.
Good Luck
Feb 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
70 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
