Question about Swisher Zero-Max 60-Inch 26HP Zero Turn Radius Riding Mower
How do i replace the hydro belt on the swisher zt2660? my belt broke after 35 hours. when i put the new belt back on it was loose and i can't figure out what needs to be tightened. i also find it very difficult to figure out how to work in the small space.
    Novelist:
  • 146 Answers
A mower with 35 hours should still be under warranty, and a belt shouldn't break at 35 hours unless you ran over something that got caught in the belt. I would take this unit back to the dealer - it is their responsibility to repair or replace your mower.
Here is my advice on how to change a main hydro belt. To get enough room to work, jack up the back of the mower (put blocks in front of the front wheels first) then make sure the back end stays up with jackstands under the chassis, or use bricks or blocks under the rear wheels. No matter what, you'll be laying on your back working in a cramped space. So don't tackle it if it's the dealer's responsibility.
If you've replaced the belt but can't get it tight, check that the idler arm spring is hooked up properly so the idler pulley presses in on the belt to tension it.
Posted on Jul 14, 2010
  • 5 Answers
I can't find the size for transmission belt for my zt2250 mower
Posted on Jun 03, 2012
Swisher zt2560 eaton hydro scimatic
You took it apart without taking notes/pictures on what went where?! Mucho intelligente!
You will have to pay for the schematic if you can get one.
Aug 17, 2016 | Swisher Zt2560 Zero Turn Radius 60" Riding...
How to fill eaton transmisson swisher zt2660
Do not fill. It is not meant to be serviced. The level should be about 3/4 in. below the cap.
Jun 28, 2014 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Can hydro oil be changed and what type oil on Swisher ZT2460 mower?
yes hydro oil can be changed and should be at regular intervals, the manual should tell you how often and the type of oil to use for best lifespan.
good luck.
Jun 28, 2014 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Do you have the belt diagram for a swisher 44" 10.5 hp pull behind? Just put new belt on, engaged blades and it started smoking then broke. I'm assuming it was too tight. Is there a tension control?
There have been issues with the bearing and the idler pulley on these machines. Here is a parts break down: http://www.searspartsdirect.com/partsdirect/part-model/Swisher-Parts/Tractor-accessory-Parts/Model-T11544/3291/1500230/P0708055/00004
Jun 05, 2014 | Garden
My swisher25hp-60 in.cut barely moves going forward
Was it working correctly earlier or is this your initial operation?
According to the product manual for "loss of drive":
1. Bypass linkages in the bypass position
2. Hydro belt worn, damaged, or broken
3. Idler spring loose or broken
1. Make sure that the bypass linkages are in
the drive or engaged position. Located at
the rear of the machine. Refer to decal on
the rear of the unit.
2. Replace Hydro belt.
3. Replace Idler spring
Apr 16, 2014 | Swisher Zt2560 Zero Turn Radius 60" Riding...
The hydro drive doesn't have much power
YES IVE SEEEN IT BEFOR SOUNDS LIKE THE BELT IS LOOSE
Jul 16, 2013 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Have zt2560 runs good, but after running about 30-40 min. seems like the hydro starts getting weak, let it cool down for a while runs great again for a while, is there a filter or something i should be...
My name is Dane and I am going to try to help you solve your problem. I've done a little research on this mower and I believe your problem could be your drive belt. Swisher Part number 6046 which is a 47" belt. I have found your operators manual at the following link:
http://www.swisherinc.com/manuals/PDF/ZT/ZT2560.pdf
I didn't know if you had the 06-046 model or the 07-152, but the belts are the same for each. Once a belt becomes worn they will give the symptoms you are discribing. You can replace the belt per this manual and all should be well.
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Dec 05, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Broke engine to deck belt after only 33 hours of mowing. Swisher needs to resolve this problem. Will they stand behind their products?
I also had the same problem, belts kept breaking after a short period of time, and the problem turned out to be the four bolts holding the engine to the frame loosened to the point the engine was tilting and letting the belt slip. Once new bolts with lock washers were installed, all has been good.
Sep 19, 2010 | Swisher Zt2350 Zero Turn Radius Tractor
Swisher Zero-Max 60-Inch 26HP Zero Turn Radius Riding Mower Logo
1,151 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
