Question about Sta Rite Starite Duraglas Inground Pool Pump 34 HP P2RA5D180L
I have a Starite pump but one of the wires is broke. I don't know where it belongs.I believe it's set up for a 220 line but would like to know if it could be changed to 115
  • 52 Answers
On the pump tag there is a schematic of the electrical. one for low voltage and on for high voltage. look at the high voltage. the A and B terminals or for the wires in the motor. the lines in are for the white and black wires coming in from your power source.connect the lines in to the suggested terminals and it will power up.
The Pool Tech
Posted on Jul 14, 2010
How do I wire a Polaris PB4-60 in the USA (115V)?
I am not sure if this will help you out any, but here goes:
Line1 & Line 2 are your Hot Power Wires coming into the motor.
It does not really matter which wire goes to which post of the motor.
This will remain true if you are bringing in 110-115-120 (these are all the same, people just refer to them differently) which also is referred to at times as "Low" voltage, and the same goes for 220-230-240 (again, referred to differently) which is referred to at times as "High" voltage.
Whether bringing in Low voltage or High Voltage, the wires you bring in will number only three:
  • Ground
  • Hot
  • Hot (potentially Hot)
Low Voltage (115) will have:
  • 1 Absolute Hot Wire = Line 1. Normally Black
  • 1 Potentially Hot Wire = Common/Nuetral Line 2, normally White
  • Ground/Earth = Normally Green
High Voltage (220) will have:
  • 1 Absolute Hot Wire - Line 1, Normally will be same color as Line 2 or Black/Red
  • 1 Absolute Hot Wire - Line 2, Normally will be same color as Line 1 or Red/Black
  • Ground - Green
In either of the above voltages, it does not matter which wire goes where, as long as a Hot wire goes onto Line 1 and the other "Hot or Potentially Hot, if 110", goes onto Line 2. Do not put a Hot wire anywhere else and Do Not put a Ground wire on either Line 1 or 2!
Most Motors are coming out of the factory wired for High Voltage Set up (220), so you will have to move some wires or a terminal block, to set the motor to operate at "Low" voltage (115). These motors are "Dual" Voltage, they have the capability to run either 110 or 220. But they don't magically know which voltage is being supplied.
Good Luck
Jun 20, 2014 | Polaris Pb4 - 60 Booster Pump
Wiring a Stark 220V 1.5 HP pool pump
you cant run a 220 pump on 110.. thats what youhave..need a 220 circuit to do this..the black is hot.. the white is neutral and the ground goes to the casing of the appliance but this wont run .. you need a 4 wire line..black/red/white/and earth ground(bare wire)..220
Dec 22, 2013 | Pool & Spa
Starite pump jwpas5f2a4
Its probably ruined the internals of the pump. You will need it rebuilt or replace it. The water is what cools and lubricates the pump. Hope this helps. Chris
Jul 15, 2013 | Pool & Spa
What does error code r =8 at startup mean? Turned heater on for first time this year. Opened gas valve at tank and shut-off at heater. Pump is running. Turned 220 v breaker on in box and "spa on"...
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Fuel lines on frame connecting to a round aparatus 2 lines on one side 4 lines on the other that go to the fuel tanks. I don`t know what the name of this part is. I broke one of the quick connects and part...
if it has no electrical wires it is a fuel filter. if it has some wiring probably a fuel pump.if you have dual gas tanks it makes more sense for it to be a fuel pump because you have a delivery line plus a return line from each tank it may also be a fuel tank switch module... as models do vary some.
Mar 18, 2011 | 1988 Ford F 250
I have- starite pump it was working fine last night but this morning there was no pressure at all i wonder if is the water tank the pump is running fine but there is no water
It sounds like you have blown your shaft-seal. When this happens the pump runs dry. If you know that you have water but it will not pump, and all the cover and housing o-rings are good, it is the shaft seal. (unless the internal impeller is just broke, but this is unlikely)
Fix: Turn off power. Remove V-clamp holding wet end together. Remove diffuser inside wet end (need flathead screwdriver).
next remove rear electrical panel on the motor. Using s 7/16" wrend, hold the end of the motor shaft by the electrical end (where you removed the cover) while turning the impeller counter clockwise (note: some impellers have an impeller screw inside which unthreads CLOCKWISE) untill impeller is off. Replace carbon shaft seal inside. Reverse and prime and then restore power and start.
Oct 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
Diagram on moter damaged. What do I change to convert from 220 to 110 V.
Please don't do this unless there is a very compelling reason for the change - you have offered no reason ... so I cannot address your reason. Pool pump motors work better, run cooler, last longer and are more economical when they run on 220 Volts.
Aug 30, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
A o smith b854 motor schematic diagram 115v . How do I hook up 115v to the factory set 230v?
Remove the back of the pump housing ... inside you will find the 110 volt connection place.
If your pump is on a dedicated line (as it should be) run it on 220 VAC ... To convert your line from 110 to 220 all you need is a double pole breaker of the proper amperage ... take the white wire presently on the ground bus bar and put it on the other side of the new double pole breaker. Then you will have 220 ... and you will save a few bucks on electricity.
Jul 11, 2010 | Smith Pool Pump Motor Square Flange - 1 HP
Low water flow
sounds like air is trapped in the system somewhere. that is why any pump will surge. check the lines going in to make sure it isn't sucking air somewhere along the way and make sure the discharge line is clear so it can pump out fully.
Jan 22, 2009 | Flotec Simer/Flotec/Omni 2105 Swimming...
Sta Rite Starite Duraglas Inground Pool Pump  34 HP  P2RA5D180L Logo
123 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
