Question about Acer Aspire 3000 Notebook
I have a laptop that works only when plugged in and the battery removed.
  • 251 Answers
Hi ,
go into your device manager / batteries and disable ''Microsoft ACPI-compliant control method battery''
you will likely need to buy a new battery eventully
Posted on Jul 14, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
I had the same problem. the battery was overcharged. I bought a new battery and now it is working well. Make sure not to overcharge the battery.
Good luck.
Please rate me good
Enercell Laptop Battery Charger Doesn't Work When Plugged In?
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Sep 04, 2012 | Computers & Internet
My acer Aspire 4741 laptop does not charge its battery. that is why every time i use it, it is plugged in. what could be the problem?
In some situations the battery can become loose. Removing it and then put it back into the laptop.
To remove the battery slide this switch to the opposite side and hold it in that position until the battery is removed. When doing this with some laptops the battery will pop out and allow you to grab onto it. Others will release the latch and require you to grab onto the battery usually with the tips of your fingers and pull it out.
In most cases this will help, but if the problem persist you may have to get a new battery for your laptop.
Good luck
Aug 27, 2011 | Computers & Internet
My computer won't turn on or charge.
You need to diagnose the problem.
>First try to take the battery out of the computer and just use the charger to make computer run.
>If it turns on it means that the battery is what's causing the problem.
>But, if computer cannot run using the charger/AC Adapter then it means that we have a problem with the charger.
By doing this diagnostics you know which part to replace.
Sep 30, 2010 | Toshiba Satellite A85-S107 Notebook
Dell 2650 DC wont work
make sure the charger you purchased has the correct voltage out and amperage(in millivolts) as requested by the laptop computer, if not you risk the chance of damaging your laptop. although they fit in the power plug, it does not mean theyre compatible. The specs should be located at the bottom of the laptop or inside the battery bay.
Apr 01, 2010 | Computers & Internet
My battery died, I plugged in the charger and the battery light flashes and then shuts off
Your battery might be completely drained. Remove your battery and and plug your laptop directly to the power outlet using just your laptop's AC Adaptor. If should now work with the battery being bypassed.
If it won't work in this way (connecting to AC Power with the battery removed), there must be something wrong with your laptop's board.
Feb 23, 2010 | ASUS Eee 4G Notebook
HP Pavilion ze2000 Laptop won't turn on
Have you tried removing the battery and seeing if the laptop will then run?
Jan 18, 2010 | HP Pavilion ze2000 Notebook
HP Compaq nc6220 Laptop is dead. no lights,
Is this the same if the charger is also plugged in??
Remove battery and retry with charger plugged in.
If same battery charger is faulty.
Dec 22, 2009 | Compaq Hewlett Packard nc6220 PC Notebook
Acer Aspire 3000 Notebook Logo
216 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
