Question about Kenmore 57029 Side by Side Refrigerator
Side by side fridge , freezer will not defrost
The freezer on my side by side fridge keeps freezing up and will not defrost i have to manually defrost it and when it freezes up it stops cooling the fridge side
  • 53 Answers
It is most likely a defrost heater or termination thermostat. they are located behind the freezers back panel
Posted on Jul 14, 2010
Freezer and drain freezing up
you either have a blocked drain in the freezer or a bad, failing defrost element, timer.
If you have a manual for you fridge you can locate the place to check for blockage in the drainline. I you dont have a manual you can check online at searspartdirect and locate one.
The heating element for the defroster is located right beneath the freezer coils so you need to take the inner panels off the inside of the freezer to get to those.
You can replace the heating element and timer fairly easily. You should be able to buy both of them for around 90-100 bucks if necessary. But try clearing the draining first. You can test the line by defrosting the fridge and pouring some water into the drain and see how quickly it goes into the drainpan below the fridge.
Good luck and be careful.
Mar 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
Fridge side warm but the freezer side cold
it sound like your defrost heater or defrost sensor in the freezer is not working,do you know if it is going into defrost every 8 hours?if you have an ohms meter you can check there parts no problem ,let me know if you want to tackle this and i will help-mike
Nov 02, 2008 | Maytag MZD2752G Side by Side Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
271 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
