Question about Proform Exercise & Fitness
My proform 360p treadmill is stuck on full incline - can it be fixed and if so how???
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Try thisSometimes incline motors will get frozen in position and need broke free. Try this:
take the motor cover off and take the screw out of the bottom of the incline motor that is attached to the screw assembly. Once you remove the screw you should be able to break the incline motor free. run the incline up and down with the screw still off( laying the treadmill on its side may make this easier). Once it goes up and down (hold the screw so it goes in and out) reattach it then run the calibration described below. If it was just stuck it should work fine.
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
If these instructions do not work to fix the incline motor
check your main harness running down the right leg for breaks in the wires or a loose connection if nothings found you can switch the red and black wires on the incline motor terminal block and see if it goes down. If it does you know you are only getting voltage to one side of the motor. There is a schematic under the motor hood that tells you what the voltage should be when you press the up or down keys. Use a multi-meter to see if you are getting the correct voltage coming from the console to the motor control board and then from the board to the motor. If no voltage from console-replace console if you have voltage from console but not from board - replace board and finally if you have voltage from console and from board replace motor. You will need to test the voltage both when pressing the up key and the down key.
Posted on Aug 14, 2010
Called pro form they seem to have alot of issues with this model. all they offer is verbal solution which doe not fix the problem. or a $400 console which doe not guarantee the fix.
Posted on May 20, 2013
2 Suggested Answers
SOURCE: proform 360p stuck on incline
I had the exact same problem.
This usually happens if you switch it off at the mains while the incline is adjusting or is somewhere other than lowest. You should always make sure before finishing off, to lower everything.
Now for the solution: If you open up the case it has 5 or 6 black philips (cross head) screws (use your user manual if you don't have your original go to proform and find the support link and download the .PDF if your model is not available get the one before or after in the same model product line (model number is below the power input)).
Make sure you remove the power before opening the cover, obviously.
Anyway, once opened, you should find a sheet of paper wrapped around in some plastic wallet. On that paper it should explain everything. Try not to mess with too much things in the settings, otherwise you might mess it up badly.
Mine is something like: Hold the speed up (+) button and then while holding the button insert the key - that will get you to the service menu (obviously the power has to be connected).
Once in the menu pressing the incline up does a self-calibration (maximum up and maximum down) after that it should be perfect.
Remove the key any time to come out of that mode and resume normal operation.
I may not find this place for any more replies 'cos i only found this site by accident. While looking for info. on my burnt out motor model: PETL 3013.6 .... But i have come across someone selling a faulty one on ebay for like 5 quids... it's picking it up the trouble!
Posted on May 31, 2009
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Incline stuck
Run the software calibration for fix it.go under the HOOD motor and follow the steps or use the owner manual
God bless you
Jul 26, 2013 | ProForm 775 CT Treadmill
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Jul 07, 2013 | Proform 400 CT Treadmill - Treadmills
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
Ifit treadmill stuck on highest incline
RUN inmedaitely the software calibration for diagnose, troubleshooting and fix it. Now that machine is running in slow speed.
sincerly. God bless you
Apr 23, 2012 | Proform 740cs/745cs Treadmill Walking Belt...
Can I dismantle proform 360p to move it
When plugging my treadmill in it was going at max speed without the key even in. Now it has slowed to a complete stop and I can not get it to move. The incline works, but not the speed.
Jul 08, 2011 | Proform Exercise & Fitness
Proform 995 sel will not incline
Try calibrating the incline.
Start the machine. While the machine is operating, press and hold the incline up button. Remove the safety key. Now replace the safety key. The treadmill should go to full incline, then back to the bottom. Once the cycle is complete, the machine should work normally.
Feb 26, 2011 | Proform Exercise & Fitness
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Jun 17, 2009 | Proform Sport 1000 Folding Treadmill...
Proform 360p stuck on incline
May 18, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,085 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
