Question about Britax Traveller Plus
Do i need to use the black bar with the snug seat?
Yes, that bar is part of the carseat.
Posted on Aug 26, 2010
Quinny zapp xtra black handle bar broken so can't lay baby back
Hi
No the grey recline / remove button on the back of the Zapp Xtra seat unit cannot be repaired. It would be a case of replacing the seat unit.
Aug 20, 2012 | Quinny Zapp Xtra in Rocking Black
Chain came off
loosten the 2 bar nuts do not remove completly the bar should move fairly freely slip chain back onto groove on bar pull bar to take out slack in chain snug bar nuts slightly there is a flathead screw behind the end of the bar next to motor tighten until chain is snug not too tight tighten bar nuts and your good to go you should be able to turn chain on bar by hand or your too tight
May 22, 2012 | Troy-Bilt Troy Bilt 18" Chainsaw
What are the steps to replace a chain on a Husqvarna 345 chain saw?
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, now remove the two 8mm nuts securing the side cover, screw the chain adjuster in the crankcase fully back toward the sprocket, assemble the guide bar over the guide bar bolts and slide it fully back toward the sprocket, now loop the chain over the sprocket and lay it inthe guide bar raiuls and around the guide bar nose, make sure the sharo endge of the cutters on the top of the guide bar are facing away from the machine ( as you loog at it, it rotates clockwise ) now align the hole in the guide bar with the adjuster pawl, re assemble the chainbrake side cover back onto the saw, and fit the bar nuts finger tight, adjust the chain adjuster so as the chain is a snug fit all the way around the guide bar, with a gloved hand pull the chain around the bar manually, so as to make sure it is completly seated in the sprocket and bar rails, re tension if needed, hold the tip if the guide bar up and fully tighten the bar nuts.
Job done.
Jan 23, 2011 | Husqvarna Garden
Hi, weare missing the bars that fit under the
If you purchased the carseat without the bars, then this is a Cabrio and not a CabrioFix carseat, and nothing can be done to adapt this to become a CabrioFix.
I hope this helps.
Aug 14, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Question
It does. However on ours I removed the adjustment bar for both the front and rear seats. The front seat seems to be more stable like this. Also, by removing the adjustment bar on the front seat it give the front baby more leg room.
Jun 11, 2009 | Baby Trend Snap-N-Go LX Double Stroller
How to remove the middle seats chevrolet venture 2001 ls
look behind the seat under the rear it's a black metal rod that runs under the seat from side to side .just above this there should be a strap sticking out the back corner of the seat .pull this strap to lay the seat forward then after you lay the seat forward reach and grab the black metal bar and squeeze the two bars together the seat will release lean it forward and lift up on the seat while still squeezing the two black bars together and the seat will lift out the track
Mar 28, 2009 | 2001 Chevrolet Venture
How to install graco seat in 99 jimmy
i think the snug rides are rear facing only. if it pulls out of a base and has a carrying handle. its rear facing only.
Mar 02, 2008 | Graco SnugRide - Clover
Sit N Stand LX manual help
For the Graco Snug Ride it should be set at position III, snap bar angle 1. Also, you can get the whole manual on the baby trend website. Here's the exact link if you need it. I had to do the same thing. Hope this helps. http://www.babytrend.com/download/2007061213547311_new_instructions.pdf
Feb 20, 2007 | Baby Trend Sit-N-Stand LX IV Plus Stroller
Britax Traveller Plus Logo
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
