Question about Microsoft Xbox 360 Controller
My wireless controller just constantly blinks green around the outside of the center x circle. it doesnt stop at the top left of the x circle like it used to. what do i do?
  • 10 Answers
If this is for your console:
*Solution* - It means your controller isn't synced with your console. At the top of your controller, there is a little sync button with waves next to it inbetween the two bumpers. Press that button once, then go to your console and press the similar button located on the front of it right next to Memory Slot B. You'll see the green light run circles around the main button for a second until they recognize each other, blink a couple of times and then you'll see the green light in the top left quadrant of the controller and the console.
If this is for the PC:
*Solution* - It could be in relation to a driver issue, power issue or both. First try unplugging any other USB devices you have to your machine besides the 360 controller. The wireless dongle used to connect to the controller uses a lot of onboard power. If unplugging everything but the controller get's the controller to sync, you might have to consider getting an upgraded power supply unit if you have a desktop or just getting a wired controller.
If that doesn't fix it, you can try uninstalling the current controller drivers you have on your system, downloading and installing the new drivers from Microsoft's web-site and try syncing again.
Posted on Jul 15, 2010
  • sean smith Sep 15, 2010
    ive tried this multiple times and still nothing.
When i try to play my wireless controller wont work the button in the middle just blinks green all around help
If you've tried properly syncing your controller and it still doesnt work you might need new ring of light board.
Dec 26, 2010 | Microsoft Xbox 360 Wireless Controller
The green light on the wall switch is blinking constantly yet it works to open/close the door. The remote does not work. Any suggestions?
Press and hold the lock button on the wall control for 3 seconds. The light will stop blinking and your remotes will work.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
My controller turns on and it just shows a green circle
try pressing the circle button on top of your controller right next to where you plug in your play and charge cable and you should see a little white button hold it and there is another one on your xbox right next to the second memory card slot. Press and hold that one to till both your xbox and controller start blinking and your controller should be fine
Aug 02, 2009 | Microsoft Xbox 360 Wireless Controller
Can't sync my wireless controller to my xbox 360
Hi
Dono if you did this the right way but when the remote goes in to sync mode in other words the green light goes flashing around in a circle,you need to press the buttton on the console aswell till it does exactly the same only then will they sync and it will pick up
the remote.
Hope this helpes
PS if you would be so kind as to rate my service i would be gratefull
thx
Slitwrists
May 18, 2009 | Microsoft Xbox 360 Controller
My wireless xbox controller keeps blinking green but won't connect
Have you tried leaving your console OFF first, and then Holding down the CENTER [X} button to turn your console on?
Usually that always works, I usually disconnect the battery clip and reconnect it (to turn it off) when it keeps blinking and does not connect.
Then I hold down the center button on the controller and move the left analog stick around in circles while it's blinking, and it usually recognizes it a lot faster when I do this.
-If the above does not work, disconnect the battery clip on the controller again and put it back in,
-But first (before powering on the controller) press and hold the tiny -sync- button on your xbox (while it's on),
-and then turn on your controller, and hold down the sync button on your controller, and move the anolog stick around while it does this also.
If the above does not solve your problem, I'm sorry, but I tried.
Jan 17, 2009 | Microsoft Xbox 360 Controller
Can't select multiplayer
you need to hit the round X button the middle of both controllers and set which profile they will use.
Do it on controller 1 first then controller 2
Jan 07, 2009 | Microsoft Xbox 360 Console
Controller
you have to press the connection buttons, one on the controller and one on the xbox 360, the one on the controller is located on top by the triggers next to the cartridge insert port right by the left button, it has 3 wavy lines next to it, when you press it, the controller will light up and go in circles. After that quickly press the button on the xbox 360 located under memory unit A, to the left of the disc eject, then the xbox 360 lights will go in a circle then automatically connect. If it doesnt work at first, try it again, but quicker.
Nov 28, 2008 | Video Game Consoles & Games
X box 360 controller
Awesome...You are THE MAN!!! WORKS GREAT
Jul 21, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
2,957 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
