Question about Samsung AS18A6RB Air Conditioner
Lights are blingking
My samsung AS09XLN air conditioner(split unit)lights are blinking. Tried starting up from remote and from the air cond unit, still the same. At startup operations, will get the usual sound and then the lights will be blinking. The compressor or the aircond fan has not started. I have cleaned the filter on the top of the aircond unit and its still the same. any solution to this would be greatly appreciated, or what are the possible causes?
  • 2,133 Answers
Thermostat command to out door unit not there . Check your PCB
Posted on Dec 07, 2010
2 Suggested Answers
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
Air cond samsung timer blingkin what problem
Look closely on the remote. Find a small slot as if you can only use a ball point to insert to it. If it has this small slot, this is the reset button. The clock would reset, the timer would be off and you can change the mode to cool for the unit to run on a/c mode.
In some remote, this could be inside the battery compartment. In some style where there are flaps that you open in order to activate some more buttons, then it would be inside .
If there is no reset button, you will just have to press the timer button repeatedly until the timer LED on the indoor unit would dis appear.
If you need any other assistance check us out at AC Delrey Beach
Mar 04, 2015 | Samsung Heating & Cooling
Both of the green lights of my samsung as09xln
Try turning the power off for a few minutes and then turn it back on...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Samsung Heating & Cooling
May 08, 2010 | Samsung AS18A6RB Air Conditioner
Samsung air conditioner light flashes and switches off by itself
It could be the temperature sensor. It is the short , usually black wire that runs across the front of the air handler. Unplug it, and check it with a meter set to ohms. If it reads a value it is good. If you get nothing it is shorted, and needs to be replaced. If it reads good, you may need to replace the main board on the handler.
GOOD LUCK WITH THE REPAIR
Mar 10, 2010 | Samsung Heating & Cooling
Not running; msg18 mini split , defrost board blinking 5 times.
check freon to low or to high. must be charged liquid 410 tank upside down.
Dec 14, 2009 | Heating & Cooling
LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Feb 15, 2009 | LG LSC121PMA Split System Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Split AC install
1. mind it - its a very simple installation
2. connect suction (or big cu. dia tube) connection to cond. unit (outdoor unit) big valve.
3. same way - liquid conn.(less dia tube) to small valve (liquid valve) in outdoor unit.
tight flare nut properly
4 provide power to indoor & run the same wire to cond. unit , you must hv got the ins. kit with wires and cu. tubes.
5. or read wiring diagram given of units for wire.
connect as per wiring dig. provided.
ravi
Jan 30, 2008 | Samsung AS18A6RB Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
1,010 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
