Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Front tires are splayed. I kick them back into a straight position and after a couple of turns both tires are pointed outward. Is this just an simple adjustment?
4 Suggested Answers
  • 83 Answers
SOURCE: Left front tire riding on outside edge.
Yes, adjust it. On lawn and garden equipment the set the tires as straight as possible. Because of there low speed the equipment it's not a huge deal. So just adjust it as best you can without any worrying.
Posted on Mar 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: two front wheels misaligned, one is straight and
To give you a professional soultion I really need a complete model number.
Here is what happens when steering becomes a problem on ANY brand of riding mower.
1. Tie rods get bent
2. Wheel spindle pivots get bent on one side.
3. Pivot bearings or bushings get worn
4. Linkages from the steering wheel to the tie rod pivot connection get bent.
On the basic bottom of the line Craftsman riding mowers the tie rods are fixed and not adjustable. However if you look for a mirror image left to right of the tie rods often you will note that one of them is bent in or out... or is shorter than the other one. There are after market tie rods that are adjustable. This is over 40 years of experience talking here.
THe best way to do an inspection of steering is to place the mower on tripods so that the fram is being supported and not the steering components and then set the steering wheel to the straight position and inpsect ALL of the steering and suspension components for the front end.
Without your model number this is quite generic. With a model number I can show you a parts diagram by item number of what to check.
Thanks for choosing FixYa,
Kelly
Posted on Aug 09, 2011
Testimonial: "thanks so much for your help..I'll do a more concise inspection of the steering components and see what happens."
  • 3911 Answers
SOURCE: my riding mower front tires
1) The tie rod between the front wheels is bent or the adjuster nut has come loose.
2) The plastic wheel bearings have gone to sh*t on either or both sides
3) The steering knuckles were never greased and their bushings are shot to sh*t.
4) The front tires have come off the rims
5) The front axle beam has been bent
Find a small engine repair shop in the yellow pages and have a person with know how put his eyes and hands on it, you will know within a few minutes what is wrong.
Posted on Sep 22, 2011
HAD A FALL WITH MY MOTORCYCLE, HANDLEBARS AND FRONT WHEEL ARENT IN ALIGNMENT.HOW DO I GO ABOUT GETTING IT TRUE AGAIN?
Hi, Anonymous if you have a minor accident, lay your bike down and the front end gets 'TWEAKED" where the front wheel is going in one direction and your handlebars are going in the opposite direction, despair not, there is a quick fix.
1. If your handlebars are turning right turn the front end all the way to the right making contact with the fork stop. Find the 10:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the left fork stop and find the 2:00 o'clock position and give it a soft kick.
2. If your handlebars are turning left turn the front end all the way to the left fork stop. Find the 2:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the right fork stop and find the 10:00 o'clock position and give it a soft kick.
Continue the process until you are comfortable with the alignment. It's always a good idea to retorque any accessible handlebar riser bolts as well as the upper and lower fork clamps to proper book specs.
Good luck and have a wonderful day.
Oct 25, 2017 | Motorcycles
How can I factory reset RX-V2092
Press MASTER ON/OFF on the front panel to
release it outward to the OFF position to turn
off this unit
Press and hold STRAIGHT on the front panel
and then press MASTER ON/OFF inward to
the ON position to turn on this unit.
This unit turns on, and the advanced setup menu
appears in the front panel display.
Rotate the PROGRAM selector on the front
panel to select "PRESET"
Press STRAIGHT on the front panel
repeatedly to select "RESET"
confirm your selection and turn off this unit
Dec 10, 2016 | Yamaha RX-V2092
What does it mean when your front wheels are not parallel? Driver side points straight forward and the front left points a little to the right.
It means that your front end is out of alignment. The front wheels should be adjusted so that both point slightly inwards at the front of the car when the steering wheel is straight. This is referred to as "toe-in." The reason why cars and trucks are aligned with toe-in is because the wheels go to a straight position when traveling on a highway due to the road resistance pushing the tires back. What you have is a "toe-out" condition which will cause the tires to wear faster at the side adjacent to the back of the wheels. Have your car aligned to avoid such uneven wear.
Feb 22, 2015 | 2002 Chevrolet Impala
How to adjust camber
move the top of the wheel inboard or outward. Positive camber is moving the top of the tire inward. Negative camber is moving the tp of the wheel outward. If you have shims add or remove then in pairs
front and back. With Struts raise the vehicle till the tires are off the ground. mark the strut at the cam bolt for a reference. Loosen the nuts and move the wheel. The angle changes when the wheel is off the ground.
Jul 09, 2014 | 1986 Chevrolet K1500
One of my tires is straight and the other one is pointed outwards. the steering wheel is sideways as like im turning
The easiest way to do this is straighten the steering wheel first Brandon. Next is to walk to the back of the truck and eye ball the left front tire from a looking from the side of the back tire. If that one is straight ahead before or after you adjust it, Now check the passenger side the same way.When both look straight, now take a tape measure and measure the distance from the center tread on the right front tire to the center of the left front tire.Say its 61", now do the same behind the front tires. It might say 58". You want to end up with the front measurement being 1/4 of an inch smaller then the back.
Feb 01, 2014 | 1999 Ford F150 Regular Cab
Tires point outward after leveling kit install
It is an alignment problem caused by you raising the vehicle 2" Have the toe in adjusted to positive and have the camber reset to positive as well. As you raise the vehicle you shorten the tie rod end making the tyres point out and the tyres will also lean more out at the top causing the tyres to scrub on the outsides. Unfortunately because you have run the tyres in this condition they will continue to wear in the same pattern after an alignment so you will be up for 2 new tyres. to fix the problem properly
Jul 21, 2013 | 2011 Nissan Titan Crew
Wheels look bent inward on front of Explorer
Take it in and get it aligned There could be something worn out that needs replacing.
May 28, 2017 | 1996 Ford Explorer
Engine will not turn over
Yes, pull out the kick start. The kick start is a bent metal lever usually located on the right side of the bike. Set the kick start lever pointing straight up, with the flat rod part of the kick start facing outward from the dirtbike. This will align the pistons, which will help the engine turn over when you kick the lever. -------------------------------------------
Launch X-431 DIAGUN III
Dec 25, 2012 | 1997 Mercury Villager
Engine turn but don't start
Yes, pull out the kick start. The kick start is a bent metal lever usually located on the right side of the bike. Set the kick start lever pointing straight up, with the flat rod part of the kick start facing outward from the dirtbike. This will align the pistons, which will help the engine turn over when you kick the lever. ---------------------------------------------------------------------------------
vas 5054a
Nov 30, 2012 | 2002 Mazda Protege
Right front tire wearing on outer edge
It sounds like a camber problem to me. Camber is how much a tire will tilt (from vertical) when viewed from the front of the vehicle. This can be expressed as positive (tire leans outward) Negative (tire leans inward) or "0" (tire treads are distributed equally on the pavement. In your case, the right front is wearing on the outer edge so it is leaning outward.
You can look at your manual but unfortunately, there is probably not an adjustment to correct this. If this does prove to be true you could pull the right front tire and get a measurement from the spindle (spindle is the term for the rod that the tire slips on to) from the front tip straight down to the floor. Save this measurement for reference because the next thing that you will want to do would be to is to get a short section of pipe to slip over the spindle and then gently bend it straight up. Not Much Mind You, 1/4" may go a long way towards getting your Camber to the desired "0"
Note: If that spindle is made out of plastic, please disregard the above as it would crack or break instead of bending.
Jan 12, 2011 | Peg Perego John Deere Gator HPX Ride on...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
100 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
