Question about Garden
Simplicity Coronet - PTO shut down while mowing,
  • 708 Answers
SOURCE: pto clutch keeps shutting off
If you have not replaced the pto switch do so. If you have check wiring from switch to the pto coil. Many times the wiring at the pto coil is rubbed by the belt until it wears the wire into. You can also try energizing the coil to the pto directly from battery (With engine off of course) If it energizes and stays energized it is probably not the coil.
Posted on May 03, 2009
  • 143 Answers
SOURCE: I have a John Deere 318. I was out mowing today
I think you have a safety switch problem. Check your grassbox switch or the cutting deck switch. Stephen.
Posted on Jul 11, 2009
  • 4 Answers
SOURCE: PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Posted on Aug 20, 2009
  • 47 Answers
SOURCE: Electric PTO won't re-engage after running OK for a while
might be rust between the plates or you need to adjust the springs tenson there are 3 bolts on it
Posted on Sep 11, 2009
Testimonial: "Adjusting the gap worked. Old gap was .037". I adjusted it to .012"."
  • 33 Answers
SOURCE: Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Posted on Mar 26, 2010
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Blades won't turn on my simplicity zero turn, I have replaced the pto switch already.
IF i'm not mistaken, this model has a safety on it, when your mowing and back up, the blades temporarily disengage until no longer going in revesre and then start back up. These are famous for getting out of adjustment, if it is out of adjustment the sensor is registering as if you are backing up. I hope this helps you
Oct 03, 2013 | Simplicity Citation 61" 28HP Zero Turn...
Simplicity
The key on the shaft may be sheared. Remove the wheel and check the keyway.
Oct 20, 2012 | Simplicity Coronet 13.5/30 Riding Mower
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 | Garden
Mar 17, 2010 | Garden
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
