Question about Garden
Have a viking linea s actually borrowed to try before buying from a friend. it did 4 strips of garden then cut out has fuel and oil. The cord cannot be pulled to restart it
3 Suggested Answers
eugbug
  • 479 Answers
SOURCE: HI THERE HAVE A POWER
The chances are that there is a problem with fuel delivery, maybe in the float bowl or the fuel filter is blocked.
Have a look at these tips:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
Posted on May 26, 2011
ftw1952
  • 10319 Answers
SOURCE: my ride on mower is
Have the pulleys checked for worn bearings and improper alignment which can cause this to happen Also the cheaper belts do break when cutting wet grass. Example.... My John Deeres belt cost $75 for a new factory one. A generic Goodyear belt runs $15. Guess what happens when I cut wet grass witha Goodyear belt? Yes it flies off. The Deere belt will stay on for it is made with a protective rubberized coating incased in fabric. If you are using a inexspensive belt you will get a lot of grief from it
Posted on Jul 09, 2011
I saw your answer to a question, about a Toyota Camry having a fuel pump reset switch in the trunk! Is there really one there, because nobody else seems to know this? Thanks
    images for Toyota Camry fuel pump reset switch
    More images for Toyota Camry fuel pump reset switch
    Toyota Camry fuel reset button Questions & Answers - Fixya
    www.fixya.com > ... > Tags > fuel reset button > Cars & Trucks > Toyota
    fuel pump reset button My car is not getting any fuel and I have been told that there is a fuel pump reset button or fuse but I am unable to locate it. If there is such ...
    Toyota Camry fuel switch location Questions & Answers ...
    www.fixya.com > ... > fuel switch location > Cars & Trucks > Toyota
    Toyota Camry cars & trucks fuel switch location questions and answers. Ask your ...Where is the fuel pump reset switch on a 96 toyota tercel? ... fuel pump switch ...
    How to Reset a Fuel Pump Shut Off Switch ' eHow
Jan 07, 2016 | Toyota Cars & Trucks
Viking 980 foot pedal not making contact with machine although machine has power.
It could be lint jammed into the jack the cord plugs into. Make sure the jack and plug are both clean and free of lint. It also could be a damaged cord. If a friend has a working Viking pedal try borrowing theirs to see if it works on your machine. If not, your machine might need service.
Sep 15, 2014 | Husqvarna Viking 1
Gateway zx4951
Pay attention to steps 6 & 7
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jul 07, 2014 | Gateway Computers & Internet
Recoil pull cord wont retract.
Buy a new part unless your capable of taking apart the motor and restring it
Jun 28, 2014 | Sony PlayStation 4
Last night I cut my computer off and it froze on the shutting down screen so I held down the power button and it cut off. Now when I cut it on the light on the monitor is orange. It's Gateway 817GM. Help?
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Jun 27, 2014 | Computers & Internet
Homelite whipper snipper amnyal needed. I need to know the size of the cutting cord or citting line size and the fuel mix for the homlite whipper snipper model HBC265JSNB SN1008015039 LwA N197 are all...
This Homelite gas trimmer runs on a 50:1 mix of unleaded automobile gasoline and two-cycle engine oil. That is equivalent to 2.6 fluid ounces (80 ml.) of oil to one gallon of gasoline or 4 tsp. (20 ml.) of oil per quart of gas, or 2 tsp. (10 ml.) of oil per pint of gas. Don't use automotive motor oil or two-cycle outboard motor oil in your Homelite gas trimmer; they contain additives detrimental to trimmer performance. Use mixed fuel within 30 days.
Feb 07, 2018 | Garden
I have borrowed a chainsaw PWR1750CSA from a friend i need to know what oil goes in the tank, i presume it is to lubricate the chain.
The fuel tank takes a 25-1 fuel oil mix, the oil tank takes a non fling chain oil to lubricate the chain, if you you a light oil it will spray off the end of the bar and not lubricate the under side of the bar where most cutting is done, if you cannot get non fling oil use as thick an oil as you can get hold of.
Sep 08, 2011 | Garden
No audio on hdmi connection
Trace wires make sure no cuts etc. check plugged in correctly. Port may be damaged otherwise. Try another cord, borrow one or buy one and return it to see if the cord is the issue or the device.
Best Reguards, Premium FixYa Support
Jul 15, 2011 | Televison & Video
I am looking for a replacement cord
Buy or get an extension cord of at least equal thickness. Cut the receptacle end off. Attach (twist the wires together and solder) the extension cord to the old wires.
Sep 20, 2009 | Viking VT400BR 4-Slice Toaster
I am borrowing my friends brand new Husqvarna 142 which has never been used and she cannot find her owner's manual. What is the oil to gas ratio?
That should be a 50:1 gas to oil ratio. Just make should the measurements are concise, and that your fuel mixture is well mixed. If anything you,d prefer to err on the side of a little tto much oil rather than not enough.
If it is brand new, I'd suggest runninit at about half speed for a minute or three, then moving on up to about 3/4 for another minute.
When you go to cut, rev the engine up to a fairly high speed before putting the saw to the wood. In most cases, you want to let the weight of the saw do most of the cutting, versus bearing down on the sae. Yhat puts undue strain on it, sepecially for a used saw. Try not to allow the saw to "bog" down, so the engine speed drops considerably while cutting.
Sirwriter
May 17, 2009 | Husqvarna Garden
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
