My lg DBRH197 hdd/dvd recorder will not tuner in digital channels. This only happened over the weekend when I turned the system off at the wall. I turned it back on and It said no signal so I tried to tune in channels again only to get 1 anolog channel. Hope you can help
5 Suggested Answers
SOURCE: Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
Posted on Mar 09, 2008
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
SOURCE: how do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Posted on Jan 01, 2009
  • 5 Answers
SOURCE: Cannot get freeview anymore
see the solution (which is basically power off, re-scan) at the bottom of this thread
http://www.digitalspy.co.uk/forums/showthread.php?t=911984&highlight=dmr+es20d
worked for me...apparantly a known bug with software 1.14
Posted on Mar 05, 2009
I can't get channels 24,30,50,63 & 80 to tune into player & yet I can get them on TV which is thru cable connected to DVD player. Therefore cannot record them
I don't have one But from the site I looked at it's only a Standard tuner so no digital channels.. sorry. here's the web link. http://www.cnet.com/products/lg-rh397h-dvd-recorder-hdd-recorder-with-tv-tuner/specs/
Sep 27, 2014 | LG RH397H DVD Recorder
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I am having trouble in connecting the new dvd recorder . I think ,I am missing some thing on the initial set up to receive the channels our present configuration is ... 1.R F cable input to set top box,...
I found your model information on a site which provided something I was going to ask you if I could not find it.DVD recorders need either a digital input from a cable box or a self-contained digital scanner(yours does not have this).So,you need to hook up as follows,External cable into cable box input,cable box output into DVD recorder input,DVD recorder output to TV coaxial cable input(usually labeled ant.)the screw on connector anyhow,you should know what I mean it seems.In this configuration,you should not need to turn on the DVD recorder to watch TV without recording because they usually have a bypass mode when there is no power on the DVD.If you have picture in picture(PIP),you should be able to use the main source to record and switch over to the PIP channel if you do not want to watch what you are recording.Do about a 10-30 second test of that just to make sure though so you don't end up all messed up.Oops.My bad...you do not have PIP.As long as the cable box is tuned to the channel you want to record,you should be able to use the TV's tuner to watch something else with no problem.When doing this on VHS recorders,sometimes the screen would get fuzzy and you would have to press the TV/VCR vutton on the VCR remote.I do not know if a DVD recorder will do it or not as I have yet to buy one,but when you do your test recording,you can mess around with whatever you want to see what happens so you will be fully prepared when you do it.If you need more help or have a problem/question,just comment here and I will get an autolink to your post and will reply ASAP.Good luck! Greg
Sep 26, 2010 | Coby DVDR1280 DVD Recorder/HDD Recorder
Unable to get digital channels through dvd player
The built in tuner in this model LG is a standard not a digital tuner.
Apr 05, 2009 | Televison & Video
DBRH197
It only has a standard definition stb in it, the unit doesnt support high def. sorry, ****-face
Jan 11, 2008 | LG DBRH197H DVD Player/HDD Recorder
LG 4912 using with a new digital TV
in order to solve the complect of channel/ choose one / if tv is digital in line w/dvd is digital.
If your your recorder is analogue choose use analogue channel.
Dec 14, 2007 | LG DR-4912 DVD Recorder
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
