Question about Whirlpool MH2155XP Microwave Oven
Whirlpool MH2155XPQ microwave range hood lights, timers, touchpad chimes, etc. work, it just will not cook food.. Can you help me.
  • 600 Answers
Probably the diodes have blown, easy fix if you can solder and use a multi meter.Get back to me if you want to try it
Posted on Jul 15, 2010
Why it does not heat food?
You didn't tell us what you were doing when you had trouble, so it's hard to say. Many microwaves will appear to work normally (timer counts down, light comes on, etc.), but they will not come on if the door isn't completely closed. Usually they have a fan that runs while the microwave is cooking, and this won't come on. If the fan is on, but the food isn't getting hot, there's a good chance your microwave is dead. You can try to call a repair service, if it's in warranty, but the cost of repair is often close to the cost of a new unit with microwaves.
Jul 19, 2014 | Whirlpool WMH32517AW 1.7 cu. ft....
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
My microwave does not heat anything. The touchpad, exahustfan, light works. The motor turns on and turn-table works for the number of mins specified but does not warm up the stuff. Please help!
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 25, 2009 | Whirlpool MH2155XP Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool microwave only cooks for limited time?
It's possible that the module that produces the microwaves is failing. The parts are cheaper but the labor may not so get an estimate before deciding if it's worth repairing or replacing.
Nov 20, 2017 | Whirlpool GH5184XPQ Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Whirlpool MH2155XP Microwave Oven Logo
230 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
