Question about Weather King 12AJA4801AH Air Conditioner
Fancoilmotor runs backwards
Fancoil motor runs backwards
  • 456 Answers
You must have installed a new motor. There are usually two leads located at the bottom of the motor plugged into another two leads.
Reverse the connection and you should have proper rotation
Posted on Jul 14, 2010
I have a Zebra 170xiIII. The feed motor runs both forward and backward. Will be running fine and I have to pause and will start running backward. Have replaced motor and same thing. What's wrong?
The DC power supply drives that motor and may start running it backwards when it begins to fail. The motor normally makes more noise than usual in both directions when it starts to fail like this.
Google "43470-002 power supply, Xi III +" and you will be able to purchase the part.
Feb 24, 2015 | Zebra 170XiIIIPlus Thermal Label Printer
140 international tractor when turn motor off the motor runs backwards
It is called dieseling. Could be carbon on the plugs or in the combustion chamber. Carbon gets hot enough to cause fuel to keep igniting after ignition is turned off.
Apr 18, 2014 | Farmall International Tractor 140 Radiator
Why is my timer runnung backwards
Timer is not identified.
Analog timers have clock motor.
If the gears strip out, then timer can run backwards.
Some timers have replaceable clock motors, such as Intermatic and Tork box timers, and pool timers.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
While small plug in timers generally do not have replacement parts.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 19, 2012 | Hardware & Accessories
When turn on the power main switch after i have spray WD40 for aircon mainteance on the fin, the operation & indicator light keep on flickering but cannot switch the fancoil unit? Thanks
Dint spray WD 40 for maintenance on the fins?? that does nothing good and apparently is dong something bad actually.
WD 40 means ,,,,, Water Displacer and it was their 40th recipe!!
Its great for removing roof sealants from your hands, or tar, oil etc, but a terrible lubricant
and the motors today require no oiling, so cut the WD 40 routine its not doing anything you want and is dong everything you dont want.
Dec 27, 2010 | Mitsubishi MS-A09WA Split System Air...
Fan motor on Carrier inside runs backwards
Sometimes a motor can start to run backwards... on an indoor fan it is usually because the air inside for some reason started the fan backwards while it was off and then when power is applied it continues to run backwards... once this happens the fan is ruined and it often will not atrt the right way even after the air problem is solved...
You will need to replace the motor and see if you can figure out why there was reversed air flow in your system...
heatman101
Aug 21, 2010 | Carrier 38CKC036 Air Conditioner
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
My PX110MX will not turn on, if I hold the on/off button down I can hear the reverse motor run but the forward motor will not run.
If you can hear the motor run that is a good thing....however there is only 1 motor...it does both jobs running backwards and forwards....if it runs backwards the motor is "probably" ok and the problem is with the pcb inside...call Royal at 1-800-524-0799 for parts assistance.
Feb 02, 2010 | Royal VF1000MX Shredder
Motor Running backwards.
flip ur wires on motors. just reverse ur polarity.
Jan 29, 2009 | Reddy R115DT Oil Filled Utility Heater
Hoover Elite motor runs when moving backwards but not forward
Are you sure its not just your belt on the beater of head slipping and needs to be replaced?
Oct 18, 2008 | Hoover Elite Rewind Bagless Upright...
Weather King 12AJA4801AH Air Conditioner Logo
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
