Question about Exercise & Fitness
I have a Cybex bike 3900 model. I replaced the battery on Saturday. The bike turned on and lighted up and worked. Now i start peddle and push start( hear the beep) the panel does not lite up.???? eebob1@aol.com
CNC65
  • 15 Answers
SOURCE: Jandy Aqualink - Rs, button control red lites on contriol panel
HAVE YOU HAD ANY LIGHTNING STRIKES?
Posted on Nov 06, 2008
dupina
  • 110 Answers
SOURCE: Singer 7426 will not start when peddle pushed - only beeps
No, dont go and buy another machine. This is a great value for money machine.
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. Pull it down and push it up to the top again. This should sove your problem right away.The beeping sound is a warning message. If the problem persist, do the following procedure:
Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 14, 2008
csmock132
  • 4669 Answers
SOURCE: No Brake Lights, unable to switch from park to drive
It is not the multifunction switch. The power feed goes thru the brake switch before the multi function. You have no power the the brake switch because your shift interlock is not allowing you to shift it. I'll look up the wiring diagram and repost with a solution.
Posted on Apr 25, 2009
  • 136 Answers
SOURCE: Singer 7422 beeps and all lights come on when peddle is pressed.
There are several sensors on this machine that just start causing the machine to malfunction for no apparent reason. One is one the bobbin winder, one on the buttonholer, and one under the machine which workd with the feed. It is far from an exact thing. If you can get to them, sometimes loosening them, moving them about then tightening them seems to 'fix' them. Sometimes not. Wish we could be more exact in explaination but sometimes we will move them repeatedly then they start working. It is hit and miss.
Posted on Sep 08, 2009
CaptainKeyz
  • 202 Answers
SOURCE: Jetta VW - 1999 won't start. Push started. Battery good. What should we look at first?
Good chance you either need a new starter, or ignition switch. Also, check the battery terminals for any sulfur corrotion. If there is, clean off with water and baking soda mix to neutralize the acid. stiff wire brush the terminals if possible, but if you do not have a memory saver plugged into the aux voltage input(cigarette lighter), you will loose Radio, TCM, and ECM programming when batterey is disconnected.
Posted on Jan 15, 2010
Brake light bulbs replaced and no light when brake applied
check the brakelight switch at the bottom of the brake peddle it could be out of adjustment, with the brake peddle released the switch should just push in a little bit and with the peddle pushed a little the switch should be away from the peddle to turn the brake lights on, hope this helps you.
Dec 15, 2016 | Cars & Trucks
Cybex 600c trotter bike will not stay in manual mode then display turns off
Does anyone have a Cybex 600C Fitness cycle owner's manual and parts catalog?
Dec 03, 2013 | Cybex Exercise & Fitness
Bike will not start. Head Lights work, but indicators flash continuously. Have had battery checked and is OK.
Sounds like the alarm system is activating. If this is a newer model, make sure you replace the battery in the key fob that comes with your bike and it will disable the security system automatically. If it is an older model put in a new battery in the key fob and push the button on the fob to disable the security system. If you can't get a battery for you fob right away, look in your owners manual to see how to disable the security system on the bike using the codes you should have entered into it when you first got your bike.
Sep 04, 2013 | Harley Davidson Motorcycles
I have a Cybex 700C upright exercise bike--it is an alternator powered unit. The display is dead. I have the bike apart, and everything looks fine inside, so I wonder if the most likely suspect is the 6V...
I would start by checking the voltage of the battery, before just replacing it. I will attach a link to a video on how to do this and also a link to the possible battery if this turns out to be the issue.
Video about How to Test Battery
Parts for Cybex Equipment Treadmill Belts Grips Pedals SPORTSMITH net
Oct 30, 2010 | Cycling
I ran my jeep radio until the battery died. I jumped it and it started but the Electronic Throttle Control light came on and when I push the gas peddle nothing happens. I replaced the battery and still...
same thing happened to me last night. Looking for an answer online like you. If you find one, please e-mail me at brian.f.mckone@medtronic.com. thank you very much.
Oct 20, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Cybex 700R will not power up.
I have a Cybex 500 and am looking for a user manual. Mine also stopped working. It's due to the internal battery running down. What you need is to plug a Power supply into the bike. I used one of these multi voltage adaptors. At the front of the bike you will see a point to plug the adaptor that fits snuggly into it. Mine was set to 12v with a positive pole to center contact. There is a diagram on the front of the bike to show you although mine wasnt marked pos or neg.
Switch mains power on and you'll get a series of displays scrolling. You'll be able to now use the bike. I left mine plugged in for 24 hours which charged the internal battery and now works perfectly again.
If you can now help me with the manual for the 500 Only want the setup pages. (1 or 2).
Thanks.
Sep 02, 2009 | Exercise & Fitness
Dead battery but dashboard lights still work but bike ownt start.
try charging first if it runs ok then the battery is bad or the charging system is bad.
Jul 01, 2009 | 2002 Honda VT 1100 C3 Shadow Aero
When I turn on the power in my Virago 2002 XV250R
motorcycle headlights stay on at all times the bike is on, kind of like running lights on a car. on some model bikes, when you first turn on the key the headlight doesn't turn on so that there is less draw from the battery so your starter can use the current your light doesn't. but once the bike is started or the start button is pushed, the headlight will remain on until you turn the key off.
Jun 13, 2009 | 2002 Yamaha Xv 250 Virago S
Exercise & Fitness Logo
50 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
