Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Paper feeder won't feed... - Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Make sure the paper select is from the tray were the paper is if you dont know put paper in top & bottom tray and see from where the paper is pulling. Note! dont put more than 5 papers at a time when testing it.
Good Luck!!
Please rate me good.
Posted on Jul 14, 2010
maverick24
  • 56 Answers
SOURCE: Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Posted on Dec 03, 2007
SOURCE: paper won't feed
my paper wont feed.please help
Posted on Sep 15, 2008
SOURCE: Paper Feed Problem
Hey I had this problem too for about 6 months. Just press the "Feed Switch" button under the main display to switch it from feeding from the tray under the printer.
Posted on Oct 22, 2008
SOURCE: Paper won't load. Media loaded incorrectly.
Okay.. 1st off I'm probably going to the jumped on for this... But.. I fix and/or make them work printers, computers and all sorts of electronic gear. For a living... Yes .. the manufacturer will tell you not to use alcohol to clean the rollers. but it does work. Windex (ammonia) will clean the heads at times. I also use Scotch brite pads to clean the pickup rollers. We get them in about 8x10 inch pads.
I will spay some alcohol on the end where the pick up roller is. Place the pad in normal paper tray. Most printers have a cam shaped one on the right, left or in the middle. That gets the paper moving. The pad is way to thick to actually move and will cause a jam indication on the printer. But what happens is the roller will slip on the pad and clean itself. Pretend you cleared the jam a couple of times and the printer will try to pick up the 'paper' and jam again. A couple of these and the pick up roller (cam shaped) will usually be good to go. The other option (the best) is to buy a new pickup roller for the printer. But cleaning will work for the short term. What happens on most printers is the roller gets very smooth from normal use and then won't pick up the paper for the rest of the trip through the printer. I have used a piece of fine grade sand paper, but you have to hold it so it won't go through the printer and it makes a gritty mess... Once I orderd a 'printer cleaner' from HP and all it was, was a couple of pieces of scotch brite glued to a fancy holder to match the spacing of the rollers. That's when I started using sheets of the stuff. Just pretend they are a piece of printer paper. In the worst case I have used belt dressing and then alcohol to clean most of it off. Alcohol has a tendency to soften the rubber on the pickup roller. That's why the company says don't use it. But you can by rubber rejuvenator that is mainly alcohol.. Go figure.........
Posted on Mar 21, 2009
komguy
  • 2306 Answers
SOURCE: my printer won't feed paper
Check the paper feed switch, you have a choice to feed paper from the back or the cassette under the paper exit. Either put paper in both or select the proper source by pressing the feed switch.
Posted on Dec 30, 2009
Epson 810 automatic feeder won't feed
do you let the paper get pulled by it'self? Maybe try to push it and maybe it will grab it better to pull through...if not try a shop to fix or buy new one.
Sep 09, 2012 | Epson Artisan 810 AllInOne InkJet Printer
Lexmark X4530 won't load paper to copy
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 16, 2012 | Lexmark Office Equipment & Supplies
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
It says paper tray is empty when it is not and so it won't feed the paper through.
It is probably asking for paper in the manual feeder. Open that door and insert a peice of paper to see if that will help.
Aug 02, 2011 | Dell 1815dn All-In-One Laser Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
When trying to print the paper won't feed through. It will on the left side (looking at the front of the printer) but won't on the right preventing it to print. I just bought and replaced both...
There could be something blocking the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder. Make sure there are foreign objects or debris that could cause this problem.
May 13, 2011 | Lexmark X4650 InkJet Printer
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
What does load mp feeder letter mean? There is paper in the printer why is the printer not prinint
load mp feeder means To load the Manual Paper Feeder
You might have selected the printer settings for manual feeding. Hence you need to feed that papers in manual feeding tray.
You can change the settings to automatic paper feeding to get rid of this error.
Aug 27, 2010 | Lexmark Optra T610 Laser Printer
The paper keeps jamming during feed I have changed it but it still jams, I think there is a fault with the feed section at the bottom but I cant find a manual that shows technical details for repairs so I...
Did you replace paper feeder with new one? Most paper feeder problem are rubber at paper pick up roller (bottom side) and small spring at bottom paper pick up roller. Check for "something" slip at paper feeder and lubrication at paper feeder mechanic.
Feb 02, 2010 | Epson Office Equipment & Supplies
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
150 people viewed this question
old marine
old marine
