Question about Dell Inspiron 1420 Laptop
The wifi connection has somehow been disconnected from my Dell Inspiron Laptop and I can no longer use it to get on line. How can I fix it?
    Problem Solver:
  • 22 Answers
Try this: if there is a Wifi switch on the side of the computer then switch the button and then try to connect. If that doesn't work check to make sure you modem or whatever your connecting to is online. Hope that helps :)
Posted on Jul 15, 2010
How do I add wifi to my dell inspiron 1000 laptop using a hotspot?
  • same way you connect to any wifi. switch on the hot spot option in the device u r using as a hot spot then go to your laptop and turn on the wifi.....if u r lucky the laptop will automatically search and give you an option to connect to the wifi hotspot....otherwise u will have to go to wifi settings of your laptop and manually search for the same....visit dell.com for further help.
May 28, 2014 | Dell Inspiron 1525 Notebook
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
How do i get my dell inspiron E1705 to connect wirelessly?
First of all make sure the Wifi is turned on your laptop.
You need to press Fn+F2 at the same time to turn the wireless on. Once its on you need to connect to the wifi network in range and you are good to go.
Thanks
Oct 11, 2012 | Dell Inspiron 1525 Laptop
Driver for Windows ME for a INTEL WiFi PCI Card B2200BG WF03?
Try e-bay or a second hand shop. ME is unfortunately no longer supported by Microsoft
Jun 13, 2012 | Dell Inspiron 4000 Notebook
I have a wifi problem with my dell inspiron 1525. It wont light up
Try to remove the battery and then connect it to the feeder, and start the laptop.
Try to disconnect the power adapter, and let go without any power source, so you can download it, then connect the power!
Feb 19, 2011 | Dell Inspiron 1525 Laptop
I have switched over to the wirless modem (wifi) system. To activate this BSNL has asked me to switch on the wireless function key on which I am not able to trace out. Please help atonce. My laptop model...
There are 2 ways of which you can enable the wifi on your dell inspiron 1525:
1) Make sure the wifi catcher on the side is set to the "on" position, this can be achieved by sliding the little switch, so the line in the middle of the switch is aligned with the ' (a line) sign.
2) The next thing that you need to do is ensure that the wifi is enabled you can enable wifi by pressing "FN" (the key on the keyboard) and F2. N.B. This will only work if you have Dell quickset installed. An alternative way of doing this is by going to start > control panel > network connections, find the wifi adapter > right click > enable.
Hope this has helped slightly, add more info if it hasn't
Thanks for reading and good luck with your problem.
Good day
Nov 04, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Wireless dirver dell model number pp41L inspiron 1545
you can find all drivers for dell inspiron 1545 here
http://www.general-search.com/download/video-dell-inspiron-1545-model-pp41l-driver-for-xp
Oct 05, 2010 | Computers & Internet
Dell inspiron 600 laptop stopped connecting to the
Hi, I think from you question your Wifi is TURNED OFF. if it is a Toshiba there is a switch on the front edge. if its a Dell there is a switch by the start button. Check to see that YOUR Wifi is turned on and active.
Take care
Jul 21, 2010 | Dell Inspiron 6000 Notebook
My inspiron 2200 laptop isn't recognizing my wireless network
verify that your wifi card is enabled in the BIOS, then install the latest driver for it. then try to use the Fix It option from Microsoft to enable WZC to manage your wifi connection : http://support.microsoft.com/kb/968682
May 10, 2010 | Dell Inspiron 2200 Notebook
Dell Inspiron 1420 Laptop Logo
122 people viewed this question
Alun Cox
