Question about Microsoft Xbox 360 Pro System Console
My xbox 360 has the top left ring red
My xbox 360 has worked great but now all i see when i turn it on is the top left corner of the power button turn red.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 120 Answers
I used the scan and pressing the open disk, I got back 2211, but there is no error code of this code. Any Help?
Xbox 360: THE LITTLE ENGINE THAT COULDN'T.
Seriously, one in three dies under warranty. Call microsoft and complain, they will be good to you. They might even let you keep your old hard drive.
Nov 26, 2014 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 Console: when i turn my xbox 360 on the power button turns ...
This sounds like the Infamous Red Ring of Death also known as Rrod. This is basically where your circuitry has just burnt out and has died. You can either take it to a Game Shop to mend it or get a new 360. if you choose the new 360 R.I.P Someones 360
May 17, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
Red flashing lights
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of Death. Call Microsoft. They have an extended 3 year warranty for this problem. hope this helps AJ
Nov 16, 2009 | Microsoft Xbox 360 Console
Why does my xbox 360 flashes red when it's turned on
you have red rings, i just left mine and unplugged the cords at the back, if that doesnt work just press the disc drive button to turn it on, that worked for me
Nov 13, 2009 | Microsoft Xbox 360 Console
Xbox360 power cycles by itself
do any lights flash etc, if so check below;
Two red indicator lights flash on the Ring of Light, or no lights flash on the Ring of Light. uparrow.gifBack to the top CAUSEThis may happen in the following situations: The auto-off setting is turned on,... loadTOCNode(1, 'cause'); This may happen in the following situations:
  • The auto-off setting is turned on, and the console has been inactive for six hours.
  • The console is too hot.
  • There is a problem with the power supply.
uparrow.gifBack to the top THINGS TO TRYTo identify and fix the problem, follow these steps:To begin troubleshooting thi... loadTOCNode(1, 'whattotry'); To identify and fix the problem, follow these steps:
  1. To begin troubleshooting this problem, check if the auto-off feature is turned on. To check if the auto-off feature is turned on, follow these steps:
    1. Start the Xbox 360 console without a disc in the disc tray.
    2. In the System section of the Xbox 360 Dashboard, select Console Settings.
    3. In the Console Settings area, select Auto-Off.
    4. Examine the option to see if it set for auto-off. If it is set for auto-off, change your selection.
  2. If the auto-off feature is not turned on and this is the first time the Xbox 360 console has turned off unexpectedly, let's do a simple test before we continue troubleshooting.
    To do this test, turn the Xbox 360 off for about 10 minutes. Then turn the console on and see if the problem occurs again. If the Xbox 360 console turns off unexpectedly again, make a note of how long the Xbox 360 console is on before the console turns off automatically.
  3. If the auto-off feature is turned off but the problem happens again, check the appearance of the Ring of Light to determine what to do next.
    • The two lights in the left quadrant of the Ring of Light flash red: The internal temperature of the Xbox 360 console may be too high. In this case, turn off the Xbox 360 console, and let it cool down. It may take several hours for the console to cool enough.
      Also, make sure that the ventilation openings on the console are not blocked. (For example, the ventilation openings may be blocked if you place the Xbox 360 console on a soft surface, like a bed or a sofa.) Also make sure that the console is not located in a poorly-ventilated place, such as an enclosed bookcase or stereo cabinet. For more information about what to do if the two red lights in the left quadrant on the Ring of Light flash red, click the following article number to view the article in the Microsoft Knowledge Base: 907533 (http://support.microsoft.com/kb/907533/ ) Two of the lights on the Ring of Light on the front of your Xbox 360 console flash red
    • No lights are flashing on the Ring of Light: In this case, we should check the lights on the Xbox 360 power supply for hints on how to fix the problem. A green light indicates that the power supply is correctly functioning.
      For more information about the power supply light, click the following article numbers to view the articles in the Microsoft Knowledge Base: 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
Jul 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 doesn't work
you have the red ring of dead which means your xbox is dead. Call xbox support and if your xbox is still under warranty theyll fix it for you.
May 20, 2009 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Video Game Consoles & Games
Open Questions:
Microsoft Xbox 360 Pro System Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
