Question about Fedders A3DH30B2A Dehumidifier
Fedders Dehumidifier # A3DH30B2A-Very Loud Noise
Fedders Dehumidifier Model # A3DH30B2A - at start, the fan makes a normal noise, but after a few moments, we hear a very loud noise as if it was an old fridge working - At that moment, little by little it starts to throw hot air instead of cool air - Instead of dehumidifying, the room gets hotter and hotter (The unit itself is not really hot-The heat comes only from the vents) - It does though throw water in the bucket below - Is this normal?
  • 883 Answers
SOURCE: dandy dehumidifier
attempt to feel the metal fins on the back of the unit. If they do not feel cool, then unit is either out of freon or compressor has failed or compressor is not running. If fins are cool, then insufficient air flow through unit -check fan- or room has very low humidity and humidistat is defective; not shutting down compressor.
Posted on Jun 24, 2007
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
SOURCE: Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Posted on Jul 17, 2008
Hey ya! To fix this u need to block that hose connection under the Dehumidifier. This will then re direct the flow to the Bucket collection mode. I have the same problem and resolved it this way after pullng mine apart. It looks like by default that hose connection at the bottom should have a plug/cap on it and after turning on ur dehumidifier this fills up then once full it starts to over flow into the bucket... Seems a strange design but thats how they have done it.
Hope this helps others.
Posted on Feb 23, 2009
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Dehumidifier started making a loud noise. Is this something we can fix?
a change in tone of the noise from a working unit indicates to me that a bit of dust/dirt has built up on the internal fans blades and has caused a imbalance in the fan now , this usually requires a complete disassembly and cleaning out to remedy
Jul 27, 2015 | Midea Westpointe 50 Pint Dehumidifier
A3DH30B2A ices up and does not seem to cycle, even at low speed
Icing is normally caused by lack of air flow. Check the air filter and cleanliness of the coil. Look for obstructions in the fans path and even a dirty fan blade.
Sep 04, 2013 | Fedders Dehumidifiers
How do I switch the water to collect in tray instead of hose hole
Disconnect the hose and replace the drain cap, that was removed to connect the hose.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | Fedders A3DH30B2A Dehumidifier
My dehumidifier run but it does not collect any water?? I have unplug it a few minutes and clean the air flitrer still the same result HELP Please
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 07, 2011 | Fedders A3DH30B2A Dehumidifier
Unit runs OK, nothing in the tank! No out of the ordinary nose.
heatman101
May 29, 2011 | Fedders A3DH30B2A Dehumidifier
Fedders dehumidifier making high pitched noise
The fam motor bearings are dry and need oil..wd-40 with the long spray nozzle maybe the best way to get oil on the bearings... some motors are sealed and it is very dificult the get them quiet again...spray right where the shaft comes out of the motor and then lean the unit back so the oil runs into the motor and let it set for awhile..then try it...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 20, 2010 | Fedders A7DH65B2A Dehumidifier
Loud noise
try to put some lubricant to smooth the work of the fan
Nov 16, 2009 | Danby DDR586R Dehumidifier
Unbearable noise
Mine does the same thing, for the third time. Seems the plastic fan on mine, lasts a little over a year. Not hard to change, just a bad design on the part. I'm ordering an extra tis time, to save on freight.
Sep 05, 2008 | Fedders A7DH65B2A Dehumidifier
Fedders A3DH30B2A Dehumidifier Logo
Top Fedders Dehumidifiers Experts
Bill Long
Steve
Shehu Pro
Shehu Pro
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
