Question about Refrigerators
I bought a used Hotpoint with the model number above. Since then I've experienced water buildup in the very bottom of the unit. I assume this is condensate that is not being removed from main cabinet. The unit and freezer both work fine but would like to fix the condensate problem.
  • 1 more comment
  • Adrian Snyder Jul 14, 2010
    I bought a used Hotpoint with the model number CTX21BASSRWH. Since then I've experienced water buildup in the very bottom of the unit. I assume this is condensate that is not being removed from main cabinet. The unit and freezer both work fine but would like to fix the condensate problem.
    The water in the bottom of the main part of the refrigerator builds up more quickly during hotter, more humid weather. The unit is not hooked up to ice maker and is kept in the garage.
    The problem area and way to resolve suggested by Macmarkus was found indeed to be the problem area and I feel like the steps I took will resolve the problem. Thanks a bunch.
  • Adrian Snyder Jul 15, 2010
    I am monitoring the condensate....and in the next couple days that will tell the tale of whether the defrost line was frozen or not. If I still see a problem I will do as you say for 24 hours and move beer to another fridge. Thanks again. This is a very useful website.
    A
  • Refrigerators Master
  • 2,605 Answers
Hello, welcome to FixYa.
Unfortunately there is no model number which appears "above" as you indicated. It just says Hotpoint.
Could you provide the model and also elaborate on where this water appears. Is it in the crisper drawer covers in the form of droplets ( condensation ) or under the crisper drawers on the fridge floor/bottom in the form of a puddle of water.
I`ll look forward to your reply and I should be able to help you from there.
macmarkus :)
Posted on Jul 14, 2010
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Jul 14, 2010
    Hello again,
    Once I submitted my reply to your question a new page opened up which indicated you had posted the model number, sorry.
    It`s one of those deficiencies here in my opinion that doesn`t allow all the history to be displayed immediately, it would save much potential annoyances but oh well, I don`t make those decisions, ha ha !
    I`ve looked up that model number and it appears the defrost drain tube is accessible ( as opposed to be built into the cabinet like some ) and that is good because I would look at that first.
    **Unplug the unit from the 120v supply before attempting any service...safety first**
    You`ll need to access it from the rear of the fridge and it is located directly behind the freezer section. pull off the drain tube and clear it out. They commonly become clogged hence not allowing the defrost water to drain into the condenser tray, but rather re-directed inside the fridge...usually under the criper`s.
    Let me know what you find and If it is indeed the problem.
    macmarkus :)
    Hey Macmarkus---
    I unplugged the fridge from power and there were two tubes on the back of the unit. One was for the water supply to the icemaker, which I don't have hooked up, and the other was a black tube leading to the bottom of the unit. It was attached to a black plastic part that appeared to have a P trap integrated and had a short fitting kinda like a compression fitting. Well I removed the long piece of tubing and it was clear. Next I was able to remove the black plastic part and to my amazement there was a BUNCH of gunk in it and also extruding out the drain it was attached to. I thoroughly cleaned the part and removed all the material from the drain and put everything back together, plugged the unit in and dried out the bottom of the unit below the crisper pans. It'll take a couple days to determine if your suggestion really worked but I feel VERY good about it.
    It's kinda funny...I bought this fridge from a friend who was having the same problem, water in the bottom, and had been dealing with it and decided he just didn't want to mess with it any more....so I got a good deal on it....It's my beer/wine fridge. Glad I did the research and found you guys.
    thanks a bunch. I'll let you know in a couple days if the drain being plugged was the problem and that it has been resolveed.
    Adrian
  • Mark MacDonald
    That is awesome, sounds like you didn`t have any trouble. Sorry I didn`t specify which line was which at the back, sometimes I just discard the water line as obvious...but I do this for a living.
    As for the line being clogged that is quite common, however I should give you a heads up. The line that enters through the back of the fridge which it attaches to should be cleaned out as well.
    The reason being when the defrost backs up to the point of leaking inside the fridge, that part will usually freeze up, so unless it is cleared you will continue to get water in the fridge.
    If it is froze up the simplest way to clear it is unplug the fridge overnight if it is just a beer fridge, otherwise you`ll have to use hot water or a steamer...careful with that. ha ha !
    Let me know how it goes. Hopefully it works out and you can invite your buddy over for a cold one with your fully functional fridge, ha ha !
    Good luck.
    macmarkus :)
  • 2,272 Answers
The water could be coming from a clogged drain cup. At the very end of the fridge, on the top part would be a plastic cup that collects the water from the freezer as it thaws the ice during defrost. This cup is connected to the hose at the back of the unit so the water would flow to the drain pan on top of the compressor or to the drain pan at the bottom of the unit. You can clean this cup after you pull it off the hose at the back. Check out.thanks.
    I'll give your suggestion a try but want input from another expert. Thanks for the quick response.
  • billy miller Dec 31, 2012
    how do i get to the drain through ( thats the piece that the funnel drain is connected to on the inside on model CTX18GAZARWW
On my Hotpoint FFA90 fridge freezer occasional leaks occur at the bottom of the freezer where ice accumulates. The fridge section above is fine. Any suggestions?
There is one in the freezer section as well. It's a small white tube. I've had the same thing happen with mine. I just took everything out of the freezer, and used hot water. It's caused by condensation buildup in the drain tube, which then freezes, obviously because it is a freezer after all. Hot water usually does the trick. Just be sure to clean it up, and dry it off really well so it doesn't re-freeze and cause the same issue.
Aug 26, 2016 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint aqualtis aqxxl129pm
Water pump in the bottom of unit is about to quit all together.might want to get model and serial number go online get factory replacement water pump for that unit. Sorry....
May 17, 2014 | Washing Machines
How to tell the model number
Is it coming out under the vegetable drawer? We just had a problem with water dripping down into the freezer. Check the drain at the lower back left of the refrigerator, above the bottom shelf to see if it is plugged. Water will be pooling there. If it is, use a turkey baster and warm water to flush it out.
I never found the serial number for our unit but used the model number from the manual.
Nov 23, 2013 | Liebherr KIKNV3056 Bottom Freezer...
I have a John Wood one pipe power vented hot water heater. The model number is Jw840nvh-fv-04. Recently I've been smelling products of combustion coming out the top of the tank where the vent is
1) Copy following link for troubleshoot resources by type of gas control valve, Venting resources, and pro water heater forum:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) This odor can indicate incomplete combustion due to lack of air supply. Get more fresh air to unit. Check that flame is clear blue color. John Wood is American/AO Smith product so air intake screen is located on bottom of unit. Use mirror and flashlight to inspect. Clean with compressed air ad or feather duster.
3) Jw840nvh is 40 gallon natural gas. Natural gas is lighter than air and rises upward, unlike propane gas that is heavier than air. Install gas detector at height correct for type of gas.
4) For safety, install CO carbon monoxide detector
5) Review product manual for correct vent lengths and diameters.
Feb 02, 2013 | Water Heaters
Dishwasher will fill and empty but no water coming through the spinners
It would help if you provide the model number.
Usually the problem is with the wash distributor circuit. The water alternates between bottom and top spinners (wash arms). The distributor may be faulty assuming the arms are clean and you have checked this. Some models use the same pump for wash and drain using impeller. In that case the problem could be the impeller is clogged and not allowing water to get in the arms. See this diagram.
Model number will help identify the part.
Dec 29, 2012 | Hotpoint Dishwashers
Wash cycle
What is the model number of the unit?
Dec 02, 2012 | Washing Machines
There is water leaking from the bottom of the door of our Hotpoint Aquarius WMA 56 washing machine. What could be the cause.
Have you been wiping the glass off in the door. A buildup of detergent crust on the bottom will cause the seal to weep.
Jul 20, 2012 | Hotpoint Aquarius WMA56 Front Load Washer
Icemaker leaking
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
My Upright freezer Hotpoint Product code 755703
My FZA 84 regularly has to be defrosted as it overheats.We do this by taking off the back panel - as shown by the Hotpoint service man here in Dublin. We use lukewarm water or a hairdryer to defrost the buildup of ice. Why its building up is anyones guess.The repairman suggested we might be leaving the door open but we certainly aren't. I'm very disappointed with the product and I wouldn't be purchasing Hotpoint again.
Jul 21, 2009 | Hotpoint Freezers
Hotpoint is not taking water inlet
If your thinking air in the water supply line, air won't be the cause. I would look to make sure there is not mineral buildup inside the valve, and that the valve is good.
Turn the water off, disconnect the line at the water valve, then carefully tirn the water abck on to make sure there is good flow from the water supply line. If there is, then look toward the dishwasher side. If not, look toward the water supply side.
Jan 24, 2009 | Dishwashers
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
