Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How do I receive faxes with the 240c - Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
  • 69 Answers
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 14, 2010
    Problem Solver:
  • 11 Answers
When a fax rings inbound press * 51 and hang up the phone. The printer will then take the fax.
Posted on Sep 22, 2010
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
On my MFC-240C I can no longer receive faxes. We
Ensure that the new telephone is plug correctly into the fax machine the. Phone line belong in the "line" socket. Telephone/answering machine belong in the phone socket. Does the telephoe answering machine work ok without the fax. does fax work with out answering machine
Aug 12, 2009 | Brother Office Equipment & Supplies
How do I change my fax number?
I found you manual to download right HERE:
- as I´m informed, you don’t need to change you FAX number, as your fax machine will receive any call on the number you connect the machine to.
5757e4d.pngdo vote, if this helped you.
regards
/Teis
Jan 16, 2009 | Brother Multi-Function Center MFC-240C...
The printer prints from the PC but will not copy without the PC
Please reset your printer to factory defaults form on screen printer menu > > >
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Can't send a fax with Brother MFC-240C
Do you have DSL or any other kind of Digital Phone Line?
Oct 03, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
BROTHER MFC 240C DEFAULT TO FAX PRINTING
We moved from 561 to 772 area code. Now we can not receive faxes. What do I need to do?
Did not have an issue receiving faxes at the old area code: 561
please email with resolution:
purplegem0713@gmail.com
Thank You....
Aug 10, 2008 | Brother Multi-Function Center MFC-240C...
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
420 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
