Question about Gateway FPD 1510 15.1" Flat Panel LCD Monitor
How do I get the monitor off power save? - Gateway FPD 1510 15.1" Flat Panel LCD Monitor
  • 69 Answers
it will allow you to enter the selection screen to pick safe mode, you just need to keep hitting the F8 key repetedly as soon as you hit the power button to turn the pc on.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 14, 2010
Monitor is on power save; how can we get it off
Will the monitor not come on at all? Its possbible you have some capacitors burned out on power board. This will cause it to go in to Power saving mode and stay.
Apr 03, 2013 | Dell ST2420L 24 inch LCD Monitor
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
How do i turn off power save mode using the screen buttons
I don't know if there is a monitor with a function button to turn off the power save mode.
As far as I know the power save mode of the monitor can be found in the display setting of the windows..
Anyway... If you want to turn off the power save mode of the monitor via windows display setting then here is what you need to do:
On control panel, double click display settings.. click the screen saver tab... on the lower portion Press the "power" button.. Select power schemes tab.. Change the settings of" turn the monitor off" to "never"
Click apply and then OK..
Hope it gave you an idea..
Much appreciated if you rate this help...thanks..
Uncheck the box
May 19, 2010 | Dell E173FP 17" LCD Monitor
Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
Every time i turn on my daewo monitor it saying "POWER SAVING MODE' then turn off power auto.
Hi this means your Monitor is in power saving mode , it is trying to save power when you dont use it, Change your power saving settings and it will work perfectly
Thanks
Dec 28, 2009 | Computers & Internet
Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
Aug 06, 2009 | Dell E173FP 17" LCD Monitor
My desktop pc has gone into power save mode
Turn the whole pc off then back on. If the LCD stays in power save then I would try a diffrent monitor on the PC. If that fixes it the the monitor is probably stuck in power save. Check www.lcdrpair.us for parts and instructions.
May 28, 2008 | Dell E173FP 17" LCD Monitor
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Gateway FPD 1510 15.1" Flat Panel LCD Monitor Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
