Question about Memorex MLT3221 32 in. LCD TV
Unit has been losing the picture sporadically for some time, usually if you turned it off it would "reset" and work.. Yesterday, the set lost power completely, and will not come on at all... the red "standby" is lit, but nothing occurs when either the remote or the manual switch is engages
  • 10,594 Answers
Seems power supply board got problem. Usually it could be few leaky electrolytic capacitors in output section of power suply that are causing incorrect voltage supply towards other circuits in tv, replacement of these leaky capacitors would fix the issue.
If you have experience of working with electronics circuits then attemp to fix it by yourself or local tv repair shop will do this job.
Hope these info will help you.
Thanks.
Posted on Jul 14, 2010
Pioneer VSX-94 lost sound
The surge probably affected the power supply. The UPS only maintains operation for a limited time in the event of power loss.
Mar 30, 2014 | Pioneer Audio Players & Recorders
The display on my Technics KN1200 keyboards is blank -I have not used it for some time but when I tried it Yesterday the display is blank -All the other Functions works well. please help Thanks Fritz
Check if there is a contrast setting knob or function. Often the contrast setting gets clobbered and then the display will be blank... worst thing if it is internal setting and you can't see the screen to change it... In that case do a factory reset on the unit. Usually this is holding down multiple buttons when turning power on.
Dec 29, 2010 | Music
Cannot maintain preset settings.
Do you have a fresh battery in the unit? Make sure your 'reset' button inside the battery case isn't 'stuck' on (push a little pencil in there).
Fresh battery, then do a reset inside the case, do a reset to factory settings, then try normal on and off with the switch and see if that fixes it or not.
Jul 25, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
I cannot watch cable TV on Input 1 when Input 2 is activated.
Tries to reset the tv Tuner board back to factory setting.By go into the tv menu.Go to PICTURE,go down to reset the Tuner board.All the HDMI ports should work now.Not,than the HDMI port 2 is shorted and dead,don't used the HDMI port 2.The tv should work fine,or tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jun 16, 2010 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Clock reset and cant find satellite
I have had the same problem. I just notice the power switch on the bottom of the unit. I believe if this one is used it will not lose power. The other power button is probably for a standby mode.
Oct 21, 2008 | Sanyo NVM-4050 GPS Receiver
SCREEN PROBLEMS
Try unplugging unit for 24 hours then, retry. Unit may also have problem in standby circuit, have serviced
May 06, 2008 | Kenwood HM-331 Shelf System
Computer won't recognize wirless network
try resetting the router to refresh it's hardware, there should be a small reset button on the back somewhere , but be aware you may lose all configuration settings if you do do this , so if you're unsure what your are doing don't hesitate to ask.
Apr 14, 2008 | SMC Barricade 7004VWBR Wireless Router
Lost all my Saved Favorites!?!
If the favorites do not show up, unfortunately they may be gone forever. Check the Recently Found and see if any are there, then re-save them. I don't know why it would lose the favorites to begin with, but once gone, they are usually gone. By the way, resetting can remove them also.
Nov 05, 2007 | Garmin nuvi 350 GPS Receiver
Memory hold on CDX-CA400 CD Player
The correct wiring is constant power on the yellow wire, switched power on the red wire. I'm not certain why you weren't able to get it to work in this configuration; the unit needs power on both wires before it will turn on, but if you lose power on the yellow wire the settings will be lost.
Jul 31, 2007 | Sony CDX-CA400 CD Player
Memorex MLT3221 32 in. LCD TV Logo
43 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
