Question about Thermador 36'' Bottom-Mount Refrigerator for Custom Panel - KBULT 3671A/KBURT 3671A
I have a Thermador 36" with bottom freezer door that seem to have a break along the seal in the upper right hand corner. I'm not sure whether the internal rail is bent or some screw is missing, but is this common problem? Because the gap in the seal, ice forms around opening and then melts. The water collected on the pan needs to be emptied every 2 to 3 days. How can I fix it? Thanks in advance...
4 Suggested Answers
  • 219 Answers
SOURCE: water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Posted on Mar 19, 2009
SOURCE: Thermador Freedom T361T70NNP - French Doors - Condensation
I have the same problem, and thermador stated there was a recall on the hinges. They are replacing the hinges to a newer stronger hinge that will pull the refrigerator doors in tighter. It took three different service companies to find the answer to this problem because I was told Thermador does not want anyone to know about this issue they have.
Posted on Aug 19, 2009
espressonist
  • 1711 Answers
SOURCE: door will not close all the way just replaced
It seems that you also a problem with the door hinges if the door seal gasket have been replaced properly. Your model have special hinges which give also a closing force which it seems that is what is missing for closing completly. The hinges have also an adjustment screws which can udjust the direction of the force and it need very carefull adjustment so the door is balanced whith frame perfectly. If the door however have big gups then the hinges or atleast one of the hinge have a problem and need to be replaced. We have here the parts diagram showing you model and the door hinges are part no 206.
Posted on Aug 30, 2011
596.77277790 freezer ice buildup in front top corner
If your refrigerator is fairly new, the seals probably are OK. More likely, the door alignment has to be adjusted.
Jan 01, 2014 | Kenmore 22.4 cu. ft. Bottom Freezer...
Ice forming in the bottom of the freezer. eventually melting and ending with water running on the floor from both corners of freezer
Check the seal on the door and make sure it is "sound". Pay particular attention to the bottom or underside of the freezer door / drawer. Make sure nothing is preventing a seal between the fridge case and door. Misfigured, distorted or otherwise damaged seals can cause frost build up as you describe. Clear any objects / replace damaged seals found.
Sep 06, 2011 | KitchenAid KBFS25EVMS Stainless Steel...
On the front of the door .bottom right hand corner there is a small amount of water coming out.when in use.
sounds like the seal is not sealing properly. check to see if there is any debris along the seal -- or any cracks in the rubber seal.
c...
Dec 31, 2010 | Danby DDW497W 22 in. Countertop Dishwasher
I have reversed the door from right to left on a kenmore refrigerator and it will not seal correct now on the upper corner
Try using a hair dryer to soften the rubber , so the magnet in the gasket , will " pull " the seal to the door .
Nov 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Lower door wont stay closed
I doubt it. The problem is probably that the unit is on an uneven or unlevel floor. Make sure all 4 corners are 'solid' and the unit is level. Is the door overloaded? Any hinge damage to either door or loose hardware?
Jan 10, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Refrigerators Logo
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
