Question about Vizio L32 32 in. LCD HDTV
Tv turns on but no picture
During a thunderstorm transformers across the street were hit. The television was on and now the picture won't turn on. it has power and turns on but there is no picture. Is there any way to repair it. and how?
  • 11,361 Answers
You will have to inspect the power supply module first any sign of damage such as burtn marks, blown parts, etc. Right now if there is any indicator light on the front, then at least the 5vdc standby is working, if none, then the main AC fuse may have blown.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 14, 2010
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
We had a really bad thunderstorm with lots of lightening the other morning-during the storm the power flickered on/off a bit. After the storm the TV won't work. It will power on-red light is visible-and...
Hi, of you have any AV devices connected to the tv, try these to verify the unit will display a picture. if so and you have an aerial caonnected to the tv, then it is entirely possible that the aerial has taken a hit and destroyed the tuner. a TV technician will be able to confirm this for you
Aug 13, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Picture went out during thunderstorm. Won't show
The television may be repairable most tv shops ask a $20 fee to look at and tell youyes or know as to how to get rid of it if you dont want to bother with it all take it to your local dump and pay $10 for correct disposal.
Honetly to me it sound like thepower board was hit and can be repaired,
Jul 01, 2010 | Philips 60PP9202 60" Rear Projection...
Had a severe thunderstorm yesterday (7/23/08). Lightening hit the transformer, all power was out for 6 hours. 3 Televisions. 1, hooked up to modem works fine, 1 hooked up to cable reciever only gets static...
Upon researching various websites regarding the Model Number for those 2 televisions that blew out, I found a few other people around the US that had the same problem with similar situations. All involving massive thunderstorm power-outages.
It appears that since out TV's are both 5-6 years old, they are worthless, both covered under homeowners but for almost nothing. It's not worth fixing. So, decided to purchase 2 more lower quality televisions as this will most likely happen again when the next storm hits. Thank god we found out that this is a repeat issue before we purchased a really expensive television.
Jul 24, 2008 | Televison & Video
APEX TV won't turn on
My APEX TV doesn't come on when the power switch is pressed.
Jul 20, 2008 | Apex Digital PF2025 20" TV
52" LG DLP
you may have had a power surge
Jun 17, 2008 | LG RU-52SZ30 52" Rear Projection...
Samsung HLR5067 flashing green
Thank you!!!! Our power was off due to new transformers being installed in the area and we had no clue how to fix this. I called around and no one seemed to know the answer (not even Samsung, who only wanted to tell me my TWO year old tv was out of warranty),so I tried this and it worked perfectly!!! You saved me a bundle! Thanks!
Jun 13, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
Vizio L32 32 in. LCD HDTV Logo
123 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
