My acer lcd is too red displayi have adjusted the color and the display is a bit blurry the model is al1916w
    Sergeant:
  • 191 Answers
Then your IC is burnt on the board and need to be replaced.
Posted on Jul 19, 2010
My Acer AL1916W LCD does not show full color. The half of the screen show one color while the other half display normal color that am expecting. I don't know how to correct it. I have use the setting...
More likely to have failing T-CON board which is part of the LCD panel assembly, you can try reseating the ribbon cable attached to the LCD panel's T-CON board first, otherwise new panel will be needed.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Color loss
Hi, right click on an empty area of th e desktop, select "Properties," next, pick all areas that will apply: Windows Color and Appearance, Display Settings... make the adjustments, "resolution etc. "Rating the solution is appreciated, thanks."
Apr 13, 2010 | Acer AL1916W 19" LCD Monitor
Image on Monitor is slightly blurry
Try reducing the screen resolution to 1/2 of what it is now!
Jan 20, 2010 | Acer AL1916W 19" LCD Monitor
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Acer LCD AL1916W
This usually means the Power Inverter board is going bad. If you're a bit savvy with tech repair, you can look up and order a replacement board - LCD inverters for MANY LCD models are available on ebay and amazon - they're relatively easy to replace. Just make sure the power is UNPLUGGED before to start taking apart the display!
Feb 13, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1916W 19" LCD Monitor color has changed to blue
Hey Buddy
My AL1916W was having same problem, its due to faulty IFB which cannot save colors after pressing reset, get it replaced from acer, if its in warranty, acer will replace ur LCD within a week.
Mar 15, 2008 | Acer AL1916W 19" LCD Monitor
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
After any game, and go back to XP, my monitor go like 8 bit color,have to power down and up
Try useing a different resolution. The native resolution should probable be 1280 x 1024. Try updateing the video drivers.
Nov 23, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W monitor
The AL1916W's native resolution is 1440 x 900. See if your display settings can produce that resolution.
Sep 22, 2006 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
