Question about Sony Audio Players & Recorders
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
  • 35 Answers
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
Posted on Jul 27, 2010
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
Am noise
in the AM frequency range, it is very hard to stop any type of interference because of the low bandwidth and not a lot can be done to suppress it, and where this band is in the frequency spectrum. There should be an AM loop on the back of your receiver, and if there is not, maybe that is why the AM reception is so poor. You can also be a better AM antenna from an electronics store to hook up to your receiver. Like I said, not a lot that can be done for interference my friend.
Jun 11, 2007 | Yamaha RX-V492 Receiver
Bad radio reception
This will be either bad antenna connection in the back of the receiver, bad antenna cable, insufficient or poor antenna type, or possibly a bad earth connection.
Feb 12, 2013 | Kenwood Car Audio & Video
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
Apr 11, 2012 | 2008 Toyota Avalon
Very poor FM receptio, and virtually no AM reception
The cascadia has an integrated AM-FM-WX, XM?, and CB antenna system, that is also prone to poor grounding. The best solution is to install aftermarket antenna systems for all of the equipment... I am driving a 2013 Cascadia with quite poor FM, and non existant AM, and WX reception. The XM works. I am afraid to hook up my CB to this, as it is pushing too much power, and is a sideband unit. I would like to hang the engineer by his/her toenails from the nearest tree for comming up with this garbage...
Mar 24, 2012 | Panasonic Car radio CD CQ-C1110GN CD...
After installation I have no signal.
Make sure the antenna is in the clear to allow it to "see" the satellite signals....
Feb 15, 2010 | Sony XT-100HD Satellite Radio Receiver
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
Dec 29, 2009 | RCA RP5430 Clock Radio
I have a Sony Walkman TV/Weather/FM/AM SRF-M37V. I need to know
The radio won't get TV sound anymore after the switch. And no, nobody is selling a digital receiver for the TV sound yet. All this radio is good for now is regular broadcasting and the weather band.
Jun 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Have a sony world band receiver ICF SW77 and can't get adequate reception in France. Any suggestions? Eithne Doy
Bon Jour!
Maybe a problem with antenna jack or possible capacitor problem. Contact me here .... poikaa(at)yahoo(dot)com
Jul 01, 2008 | Sony ICF-SW77 AM/FM/SW Radio
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
209 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
