What is the cause of ff code on wall unit
We have a saunier duval air conditioning unit. what is the cause of ff code in red on wall unit. Remote doesn't switch on or off. remote looks like it's working but no response from the unit.
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
  • 15 Answers
SOURCE: I have a Saunier Duval
That code means low pressure.
The unit has either lost it's refrigerant charge or the coil is dirty. Look at the unit and find the metal fins. Make sure they aren't plugged up with lint and hair. There are two coils on an air conditioner, one inside and one outside. It won't hurt to check them both.
If cleaning the filter and coils doesn't fix the problem, it's time to have a technician come and check the refrigerant charge.
Posted on Sep 19, 2008
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
SOURCE: Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
Posted on Jun 02, 2009
burty681
  • 56 Answers
SOURCE: low pressure for SAUNIER DUVAL
there is a blue tap at the bottom of the boiler when you turn it and nothing happends the screw had broken off inside you can do 2 things here put a new filling tap on the boiler , or get a filling loop put some where else on the system and if you still get low pressure replace the low water pressure switch...
Posted on Jan 31, 2011
SAUNIER DUVAL model 31-026. Where can I obtain a troubleshooting manual?
Boiler Manuals: Saunier Duval - Plumbase
https://www.plumbase.co.uk/documents/index/10000204
Boiler Manuals for the Saunier Duval range. ... Saunier Duval Thema Range · Saunier Combitek F23E · Saunier Duval Isomax F28E · Saunier Duval Sylva ..
Aug 20, 2015 | Heating & Cooling
Error code "ch12 for LG PQRCUSA0
Connect the remote controller cable to
the wired remote controller installation board as shown in the right picture. 12V SIG GND Red wire Yellow wire Black wire 12V SIG GND 4. After fixing the
top part of the remote controller to the installation board as shown in beside picture, press the bottom part to assemble the controller to it's board. When
disassembling the remote controller from the installation board, use the driver as shown in the right picture and insert it into the hole with the arrow. And
when you pull the driver in the front direction, the remote controller will be separated. Wall Side Wall Side ENGLISH Red Yellow Black Remote Controller
Cable ?The remote controller cable is connected as factory default. Wall Side Wall Side 2. After fixing the cable to the guide slot, attach the wired remote
controller installation board at the desired location.
Mar 02, 2015 | LG Heating & Cooling
Saunier Duval ISOFAST F35E on hot water only makes a noise like a motor bike that vibrates through the pipework, this does not happen when the central heating is on, any ideas as to the cause.
The water pipes (steel) are probably full of rust. The noise is air in the pipes.
Use the pressure relief valve to let air escape.
The risk is if the relief valve is old it may not shut off.
Also air will build up again
Nov 05, 2014 | Water Heaters
Hi, I have a Saunier Duval? Theilea twin 28e
You may want to check the Pressure Reducing Valve On the supply line to the building. Easiest way to check is get a guage that hooks up to your hose bib (usually found in the sprinkler section at your hardware store). If your pressure is getting above 80, you need a new PRV.
Feb 14, 2011 | Water Heaters
Low pressure for SAUNIER DUVAL TERMACLASSIC
Jan 31, 2011 | Heating & Cooling
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
Hi, Got a Saunier Duval Thema F 23 E and need to repressurise it (currently at 0 bars). can you provide any help on how to do it? Thanks.
http://www.saunier-duval.co.uk/manuals/pdf/noncurrent_products/installation_ThemaF23e-SBF23e.pdf
Here are complete instructions for installation and service including purging air and refilling. One of the first suggestions is that service is to be referred to a competent technician.
Gary
Dec 18, 2010 | Water Heaters
I have an E1 error on my airconditioning unit...no remote and no access to get one...is there anything I can do?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 16, 2010 | Haier HWC08XC1 Wall/Window Air Conditioner
My FEDDERS air conditioning/ heating through the wall unit won't respond to my remote - the batteries are new and the screen on the unit won't change from " E2 ". Perhaps it is related with the snow?...
First you have to confirm if the remote control is defective. Use your cell phone camera to check the remote control transmitter. Using your camera as your eyes point your remote control to camera and "on" your remote control, light should emit in the remote control if it is good. Try to reset the error in the unit by disconnecting the power supply for 10sec. and operate the unit.If it the error code still present after the reset then you need a qualified technician for this problem.
Dec 18, 2008 | Heating & Cooling
I have a Saunier Duval aircon unit SDH 31-035w. It runs for 30 seconds and then switches off and displays the message L6. What does this mean?
Sep 19, 2008 | Heating & Cooling
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
