Question about Amana NAH6800AW
I have a Amana washing machine nah6800 .The problem is the fabric sofiner wont despense at all. Whats the problem thanks.
zaids
  • 456 Answers
SOURCE: fabric softener does not despense
may be the dialer is not working to that function
Posted on Dec 10, 2007
I had the same problem with mine, and just added water in with the softener to fill it 'to the line' - and it's worked since!  Can't hurt to try!!
Posted on Jan 20, 2008
SOURCE: AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
MOdle NAH6800 I beleive its either 2 or 3 years old. I have water in the outer tub. I can hear it when I turn the tub is this normal
Posted on Mar 21, 2009
localwonder
  • 6784 Answers
SOURCE: washing machine wont go out of first cycle
Hi, you will need to replace the control unit in this washer asap. it has failed due to circuit damage locate din the logic sector.
Posted on May 30, 2009
  • 215 Answers
SOURCE: THE FABRIC CONDITIONER COMPARTMENT ON MY BWM129
The conditioner works by sythening, to do this water is diverted to the conditioner compartment. Lift this out ond check hole is clear in the little conditioner pot. although this is comman on many machines
Posted on Feb 10, 2010
Fabric softener does not despense
Dec 10, 2007 | Samsung WF337AA Front Load Washer
Have an Amana NAH6800, I must unplug it and plug back in to get it to start wash cycle. Also, keybord is locked until a couple of minutes after the wash cycle starts. Called repairman, he said control...
WELL IT IS POSSIBLE THE SECOND CONTROL BOARD WAS BAD ALSO? A 6 YEAR OLD WASHER IS YOUNG U CAN GET A GOOD 10-15 YEARS OUT OF A WELL KEPT WASHER.
Dec 03, 2014 | Amana Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
The detergent dispenser want despense the fabric softner
Hello. This is a common problem due to the fact that fabric softener collects in the dispenser and gums it up. Begin with an empty washing machine. Add two cups of vinegar to the fabric softener dispenser and then run the machine on the maximum water and hottest water setting. Once the cycle is complete check it out. It will be as clean as a new machine. If this treatment didn't completely clean out the dispenser, repeat the cleaning a second time with two more cups of vinegar. regards, Joe
ps - kindly rate my answer as helpful. Thanks.
Feb 10, 2010 | Washing Machines
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
GE Front Loader will not despense Fabric Softener
We checked the cold water line that goes into the washer, it had some pretty nasty stuff in it, and once we cleaned it out, and soaked it in CLR, it cleared up the line. Once we reattached it and ran a cycle, it went great. I am assuming with the line being clogged it didn't have enough water pressure to flush out the fabric softener.
Apr 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Machine will not use fabric softener
the despenser has a servo motor on the top of the despenser, you have to remove the top of the washer to get to it, it is on the left side of the unit looking form the forunt, check the motor woth a vom meert on resistance, if you get a reading, meter needle moving twards the right the motor probally is good, if no eter movement the the motor is bad
if you have meter movement after checking the motor then the control board is bad
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Amana NAH6800AW Logo
42 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
