Frigidaire front load clothes washer. Model # FTF2140FS. Water is sitting in the bottom of the drum & won't drain out. Can't run a spin cycle or regular cycle to remove it.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As the water won’t drain out so it seems to be an issue with the drain hose, you’ll need to remove the lower front panel and then remove the hoses from the pump to check for any clogs/foreign objects. You can also check the pump assembly which is located in the front right corner. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 14, 2010
Frigidaire GLTF2940ES Washer. Clothes are soaking wet at end of cycle.
Suggestion:
WARNING: POWER OFF and UNPLUG WASHER. There are
intentionally ungrounded areas inside machine. Behind the kick panel at the bottom of the front (Two screws on the bottom front of the panel) you will find the Technical Data Sheet for the washer. Follow the instructions for running Diagnostics on page 2. When u get to step 9 the washer will test the spin cycle (give it a minute or so to start). That will at least see if your belt theory is correct. I am NOT a washer tech so I am only telling you what I have done with the same problem. I have not yet repaired it as this is a new problem, but the diags gave me an error code I am seeking info on now. Good luck!
Jun 25, 2012 | Frigidaire GLTF2940ES Front Load Washer
WILL NOT DRAIN OR SPIN
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 04, 2012 | Frigidaire FTF2140FS Front Load Washer /...
Washer not spinning out he clothes are soaking when done
You will need to clean the water filter and or water pump. Remove the bottom panel you'll find the water pump and hoses to it use a bunch of towels as the hoses will hold water. When that all done and it still doesn't drain then your pump needs to be replaced.
Sep 26, 2011 | Frigidaire FTF2140FS Front Load Washer /...
Washer not draining
sorry about this problem,we get this alot your drain pump is clogged,so try this take cloths out and see if you can scoop out water.Now put rooto-roter drain opener in drum and let it sit for about 1-2hrs.Now run on heavy-duty by itself it may have to go through 2 cycles,to clear out clogg.See the drain pump is real small,so dog hair,strings,or pieces of rubber from throw rugs well clog pump.So first try this.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Owners manual for model#FTF2140FS
my washer will do all the cycles but will not spin out the water I have tried to run it through an other cycle sometimes it works sometimes it don't any suggestions
Jun 18, 2010 | Frigidaire FTF2140FS Front Load Washer /...
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
