Question about Canon MP-25DV Calculator
How do i install a new ribbon in my mp27d canon calculator
old marine
  • 1973 Answers
SOURCE: CANON MP27D CALCULATOR
1. Set the Power switch to ON and the GT switch to OFF
2. Press the Calendar / Clock button
3. Press and hold the Time Set button for 3 seconds
4. Enter month (2 digits), date (2 digits) and year (4 digits)
5. Press the Time Set button
6. Press the Clear / Clear Entry button
Posted on Jun 13, 2008
SOURCE: lost manual
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
Posted on Jan 27, 2009
  • 3278 Answers
SOURCE: canon mp27d manual is lost
Hello.
So sorry, but Canon has not produced a manual or user guide for your calculator.
All you have available is a product brochure, found here:
http://downloads.canon.com/cpr/software/calculator/Full_Line_Calculator_Brochure_2007.pdf
If you look on page 58, you'll find some info about your calculator.
Hope this helps.
Posted on Apr 03, 2010
  • 16 Answers
SOURCE: need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Posted on Apr 28, 2010
  • 102366 Answers
SOURCE: I need the user manual for a Canon MP27D desk top
It's not exactly the same, but the manual for the MP27-G should serve.
http://www.usa.canon.com/app/pdf/calculator/MP27-MG.pdf
Posted on Feb 10, 2011
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
How do I correct blurred calculator printing
Cleaning the print head and replacing the ribbon should take care of this for you
Nov 29, 2015 | Canon P170-DH Printing Calculator
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
I need the user manual for a Canon MP27D desk top printing calculator.
Feb 10, 2011 | Canon MP27-D Calculator
Need to replace ribbon on canon mp25dv calculator
Apr 27, 2010 | Canon MP-25DV Calculator
Canon mp27d manual is lost
Hello.
Hope this helps.
Apr 03, 2010 | Canon Office Equipment & Supplies
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Apr 20, 2009 | Canon MP-25DV Calculator
Lost manual
Press C/CE.
Dec 19, 2008 | Canon MP-25DV Calculator
Jun 12, 2008 | Canon MP-25DV Calculator
Canon MP-25DV Calculator Logo
328 people viewed this question
old marine
old marine
