Question about Porter Cable PCH3200 Commercial Pressure Washer
What typ of gas do i use
Porter cable
pressure washer
5.5 horsepower
2500 psi
2.5 GPM
pc2525sp
  • 760 Answers
Regular gas 87-89 octane works fine.
Posted on Jul 14, 2010
How do you adjust the pressure?
get larger nozzles, if you are using size 4 nozzles now ( looks right for 3 gpm at 2500 psi) then you would use size 4.5 for 2000 psi, size 5 for 1600 psi etc
Chart here https://www.stens.com/assets/media/pdf/2012_Nozzle_Size_Reference_Guide.pdf
Sep 07, 2014 | Dewalt Pressure Washer - DXPW3025
Where do i get a 2200 psi pump?
It depends on what you want the pump for, but at 2200 psi, I presume you are looking for something like a pressure washer pump.
Harbor Freight sells a 1600 or 2500 psi pressure washer
http://www.harborfreight.com/2500-psi-3-gpm-65-hp-212cc-pressure-washer-69734.html
If you need just the pump, here are a couple of websites to check out:
Pressure Washer Direct
http://www.pressurewashersdirect.com/power/pressure-washer-pumps.html
Northern Tool
http://www.northerntool.com/shop/tools/category_pressure-washer-accessories+pressure-washer-pumps?utm_source=Natural&utm_medium=Covario&utm_campaign=Pressure
And you can check on Amazon or eBay and see if someone is selling one there.
Sep 04, 2014 | Garden
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Wel-bilt power washer stalls after it heats up to running temp
pump lacking lubricant ,some are sealed.remove pump and inspect
Aug 17, 2013 | Welbilt Vertical Gas-Powered Pressure...
No pressure
you will have to try the following start up purge up onece with just water then start the powerwasher if that does'nt give u pressure ther is gaskets inside the pumping sometimes 4 to 8 of them these might be to wore down to hold pressure if u can locate the pump and desemable it run it to ur local dealer tell u need new gaskets put into it
Apr 09, 2010 | Porter Cable PCH3200 Commercial Pressure...
Porter Cable PCH3200 Commercial Pressure Washer Logo
88 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
