Question about Corel Photo Paint 8 for Mac
PP8-Windows 7 compatibility patch?
I get messages like: "Photopaint has stopped working." Or: "mem_bad_handle" Or: "mem_bad_pointer" Or a variation of same. Then: "SmartHeap error handler recursively re-entered". Sometimes the program works for awhile, then freezes up. I may be in the middle of editing or saving a pic when the program quits. I guess I'm looking for a patch. Where can I find one, please?
Windows 7
Someone need windows 7 key can go link http://www.vinhugo.com
to got. my key got here and after i used my windows works properly.
Apr 29, 2014 | Video Cameras
Please some 1 say how 2 run brian lara 07 pc game in windows 7? an dialoge box appears saying it has stopped working.
Its supported os are WINDOWS XP/Vista.
HOWEVER not to worry. Right click on the game icon and select properties. Click on the compatibility tab and tick the box in the compatibility mode section. Select either xp or vista and click apply.Stat the game and hopefully it works.
Oct 01, 2012 | Codemasters Brian Lara International...
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
Trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit? any suggestions around...
Title: trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit
First of all download compatiable driver for that printer for win 7and install it
May 08, 2011 | Computers & Internet
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I download the drivers but when I go to install it says it cannot find them
Depending on the make and model of your computer and operating system, you'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until you're prompted to restart your computer.
Restart your computer.
Install the proper drivers. You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
If using Windows 7, install the Vista drivers in the compatibility mode. Vista 32-bit for Windows 7 32-bit and Vista 64-bit for Windows 7 64-bit.
Links to the patch/drivers and installing in the compatibility mode can be found at...
924 Photo All-In-One Printer owners thread (W7)
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
Vista wont run Mavis Beacon 8. Start it and short...
well you know what Mavis is like ( a temperamental ole bird at the best of times, but don't say l said that ok )
Anyway it's not compatible with vista windows 7, you'll have to git with the times and git windows 10 if ya wanna run it as there are no patches. Sorry fer the bad news..
Dec 04, 2017 | Broderbund Mavis Beacon Teaches Microsoft...
Can i get corel photo paint 8 to work with windows 7
I know it won't work right with Windows Vista, forcing me to go back to Windows XP. Now with all the daily updates from Windows for XP, I am starting to have trouble with Photopaint 8 again. It is like 15 years old, but it was one of the best graphic editors out there. I wish they would just take what they had with PP8, and make a new version compatible with Windows 7. Seems like all the Corel upgrades to PP8 changed it completely and ruined it.
Apr 30, 2010 | Corel Photo Paint 8 for Mac
My Corel Draw 8 locks up when I try to save my project. Any suggestions. I am using Windows XP
I have seen this under XP SP3. The following solved the problem for me.
Install Corel 8 from the CD. Reboot.
Get the 369 and 433 upgrades from the Corel FTP site. (Those upgrades are no longer available on the web site, but there is a pointer to the FTP site on the "Updates and Patches" page).
Apply the 369 patches. Doesnt matter what version the CD is -- the patches check to see if they need to be applied. Reboot.
Apply the 433 patches. Reboot.
Start the XP Compatibility tool. Make the settings for PhotoPaint and Draw "Windows 2000", "No XP Themes." Reboot
Mar 10, 2010 | Corel Draw 8
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
Corel Photo Paint 8  for Mac Logo
438 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
