Question about Frigidaire FAM156R1A Wall/Window Air Conditioner
Frigidaire fam156r1a conpressor wont start,fan slows down and i hear light click.click is coming from what looks to be a sensor that sits unattached on top of conpressor.when click happens you can see a green light shining thru bottom of senser for a split second. a/c continues to run/fan
SOURCE: freezer/ fridge not cooling, compressor not running
this refig has 2 independent temp controls one that operates the freezer side (this one also operates compressor, condenser fan and evporator fan) and one that controls the temp for the fresh food side this one operates a damper and evaporator motor.
I looked up you model number and you need to check the control that is located to the left side of the control panel or the freezer control. if it is 60f in the unit then if this control is good it should read infinity on a ohms meter. if its bad you will get no reading at all. alternatley you may try hitting the control solidly with the **** of a screwdriver sometimes the contact will hange open. message me back if you need further assistance. peyton...
Posted on Jan 28, 2009
SOURCE: frigidaire dishwasher wont run
Thanks for your help. My dishwasher did the same thing today -- green lock light came on and I couldn't get it to run. I checked the bottom of the tank and I had some glass lodged in the drain. Cleaned it out and held the button down for 5 seconds and now it runs again.
Posted on Feb 28, 2009
SOURCE: Frigidaire LEQ1442ES won't start
You can check the solinoid valve which is working properly.
Posted on Jun 15, 2009
SOURCE: I have a Frigidaire top freezer refrigerator which
the evaporator fan is not spinning. the coil is getting too cold because the fan is not circulating the air across it. defrost it and see if the fan works. If not, they are fairly inexpensive and easy to replace. There is an access cover on the back wall of the freezer. remove it, and the fan is right behind it.
Posted on Nov 20, 2010
SOURCE: can a frigidaire (mod.no. fam156r1a)
Hello, yes the unit can be recharged but a piercing valve must be added to the low side of the system in order to do that. The valve pierces the tubing and then the refrigerant can be added.
Posted on Apr 25, 2011
Dec 09, 2013 | Star Enerco Heat HSU45 Garage Heater 45000...
Jun 22, 2012 | Cars & Trucks
Sep 25, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Apr 25, 2011 | Frigidaire FAM156R1A Wall/Window Air...
Mar 04, 2011 | Frigidaire Freezers
Oct 17, 2009 | Frigidaire FAM156R1A Wall/Window Air...
Mar 11, 2009 | Dryers
Jun 30, 2008 | Sony Playstation 3 (PS3) Console
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Sep 23, 2007 | Frigidaire PLCF489AC Dual Fuel (Electric...
Mar 16, 2013 | Frigidaire FAM156R1A Wall/Window Air...
Jul 19, 2012 | Frigidaire FAM156R1A Wall/Window Air...
