Question about Texas Instruments TI-83 Plus Calculator
Screen has a line down center
It's hard to see numbers. Is that repairable?
  • 76 Answers
If it's a complete line down the screen, then likely no. On the LCD screen itself there are these tiny, thin plastic ribbon cables that attach your screen to the circuit board inside and once it tears, it's gone for good. If the calculator is relatively new, ask Texas Instruments' support team to see if you might be able to get either servicing or replacement.
Posted on Jul 14, 2010
Purlpe line down the middle of my vizio sceen
a number of possible reasons: bad connection from a board to display panel, a bad connection inside the display panel, a defective board that drives the screen and a number of other reasons none of which are easy to find or fix.
Aug 27, 2012 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
Thin red line down the center of my screen
I'm afraid you'll need a tech on this one.  It could be the panel itself which would be beyond economical repair. If you're lucky it may be a bad connector/connection.
May 17, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
No image in my screen
When you ask for help, give make and model number. In this case, if display is a CRT type (cathode ray tube, not LCD), then a horizontal single line in the center of the screen indicates a lack of vertical deflection. If it is a vertical line in the center of the screen, it is a lack of horizontal deflection. Both problems can be caused by any number of components, all internal, and requires a technican to repair. Lowrance has a fixed fee system for their factory repairs. See their online info for support: http://www.lowrance.com/en/Support/Service-Information/Service-Rates/
Sep 30, 2009 | Lowrance Boating
My model number is ds27820 and i just get a thin line
This is a common problem with the vertical output IC and vertical section. (if the line is from left to right in the center of the screen)
Most shops will repair ths problem for under $100
Sep 28, 2009 | Sanyo DS27510 27" TV
I have thin white lines that run across the top of my picture. They are only visible when picture is full screen. The wide screen picture (with the black areas at the top and bottom) do not show this. The...
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Aug 10, 2009 | Televison & Video
Red line in the middle of my plasma screen
Hi leprecoce,
One transistor out of millions has failed shorted. That is an unusual failure mode, but not unheard of. The chip can probably be replaced, you might want to check google maps or http://tvrepair.com for a repair shop near you.
Most shops should be able to give you an estimate, I would guess around $300, unless the chip is hard to get.
Nov 01, 2017 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
Screen fading with lines in it
I had the same problem with mine - it is 5 years old and very well used. I was told I could send it for repair, but opted to purchase a new unit. You can find service centers on line. The cost did not seem to justify being without GPS and then still having a well used system. This was the best solution for me.
Jan 05, 2009 | Furuno GP32 GPS Receiver
Cracked screen
Unfortunately, the only way to "fix" this is to replace the flat panel itself. This is not a cheap repair. I don't have a source for parts for your model. I would check with the place of purchase or look in the owner's manual for a service center and inquire about the replacement parts cost. Be prepared for a large number.
Dan
Sep 10, 2008 | Zenith L20V36 20.1 in. EDTV-Ready LCD...
My samsung SPH-m500 is freeze and lock with a big syder on screen and nothing work on it ????
You will need to turn the phone off for two minutes. And then turn it back on. If this doesn't work, then try doing a hard reset which returns the phone to manufacturer settings. You will lose all contacts and data by doing a hard reset. Make sure contacts are copied down. You will need to reprogram your phone after hard reset. If this doesn't work then you will need to visit a repair center. There is a nominal charge for diagnostic and repair if this issue with your phone is still freezing up if you do not have any repair insurance on your phone line. Hope this helps.
Aug 19, 2008 | Samsung Cell Phones
Texas Instruments TI-83 Plus Calculator Logo
268 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
