Question about Cakewalk SONAR 4 Producer Edition for PC
PLaying and Recording
Ive used sonar 4 here for awhile, and it does a fine job...but one day out of the blue, i lost the ability to record and playback. not input problems, its just not even enabling the program to play or record.
spacebar, armed R don't function
and neither does manual mouse clicks.
help?
  • Anonymous Oct 26, 2008
    ive used sonar 4 here for awhile, and it does a fine job...but one day
  • 39 Answers
I`ve met with this problem before in another version of Sonar.
I think you must have been playing around with your audio settings. If you go into the audio settings, one of the tabs on top will open up the drivers selected window. Make sure you have your soundcard driver whether Asio, MME or WDM selected in the palyback and recording timing. Myself I use Asio4all drivers which are freely available on the net.
Initially when I chose asio I could use midi but no audio so I was using MME, but that has too much latency. Eventually I used WDM, but nowadays I use the Asio4 all drivers.
Please remember to exit Sonar and restart after any changes. You might need to do the same again for eith the record or playback timing masters as I don`t think you can change them at the same time. In any case, once you change one and restart the program, youcan then select the corresponding one and restart again. After that you shoudl be fine.
Posted on May 14, 2009
Look in your MIDI instruments and make sure the icon for you to play back is lit.
Posted on Jun 17, 2008
HI ITS ALDO FROM MALTA .I HAVE THE USB SOUNDBLASTER 24 BIT- MODEL: SBO300 AND I LOST THE CD .I CAN'T USE IT WITH SONAR 7 FOR RECORDING.THANKS FOR YOUR HELP.
Hello there sir, FixYa premium expert is on your service today!
Well you can use it with sonar 7 for recording, just read manual you got with you Sound Blaster and it will all become really clear to you.
Please rate my answer, thanks in advance.
Apr 22, 2011 | Creative Labs Sound Blaster Live! 5.1...
Thing is that im recording a song. After recording when i try to play it, it doesnt give any sound. Im positive that it records fine. Any solutions?
This is totally dependent on the software you are using to record.
Not knowing what you are using makes any response a wild guess.
IN GENERAL you must configure both the input and output device within the recording software you are using.
I use Sonar and one has to select the audio input and output device and tell the program which device is used for timing.
Aug 07, 2010 | Lexicon Alpha Personal Recording Studio
Timing after recording. and midi composing
May I suggest you try to adjust your audio settings inside Sonar. Also it is a good idea to always keep your C drive well defragmented. I once had this problem using Sonar LE and the only way I got rid of it was after formatting my C drive and reinstalling the drivers and Sonar again. After that the problem came back and then I upgraded from the SB Live to Audigy SE.
Make sure you also have lots of free space on your C drive and have a decnt amount of ram.
May 11, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Sonar 4 and midi sound cuts offat start of playback
If you are recording from bar 1 at time 1.00 you might want to start recording one or two bars later. So try starting your song on bar three istead of bar 1
Mar 22, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Me and some buddies record with sonar home studio 6 and i bought a new pc custom built for recording well our computers on tha same day and time started having problems with sonar popping and glitching...
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Mar 06, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Camcoder (Panasonic PV-GS15) does not play back recording
Sorry to say- but it is trashed.. It would cost more to fix it than it would be to buy a new one.
May 06, 2017 | Panasonic NV-GS10 Mini DV Digital...
I have a recording software called Sonar 6 and every time i try to start it, i get an error message saying "sonar has stopped working". I have had the software for a few months and it's only just...
HAI,SONAR 6 SOAFTWARE WORKING PROPERLY IN THE MIDDLE IT'S NOT WORK OR FIRST YOU HAVE INSTALL THE SOAFWARE THAT TIME WILL NOT WORK.ANY WAY UNINSTAL SONAR AND REINSTAL IT'S WORK FINE.
UNINSTAL :
START>CONTROL PANNEL>ADD REMOVE PROGRAMS>SONAR>REMOVE.
RE-INSTAL :
DOUBLE CLICK FOR EXE SETUP PROGRAM FOR SONAR>SELECT TARGET AREA(DEFAULT C:\)>FINISH.
RESTART SYSTEM AND USE SONAR.
Jul 05, 2008 | Computers & Internet
Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Mar 13, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Playback difficulties
Not specific enough but I would run a head cleaner thru it for 10 seconds and see if that improves things and always use the same brand of tape to prevent gum issues.
Jun 01, 2007 | Canon ZR60 Mini DV Digital Camcorder
Cakewalk SONAR 4 Producer Edition for PC Logo
240 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
