Question about Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Dryer model # MDE5806AYW Quiet Series 200 today we had to replace the belt but we took the top panel off the dryer including the control panel and disconnected the wires but now i forgot how to connect the wires the colors are blue, two white, one black, please help
  • 259 Answers
Http://www.apwagner.com/large_image_viewer.php?image=images/diagrams/00191/i385263.GIF
Here is the link to the wiring diagram for your dryer, I'm assuming you are looking for the wires as they connect to the incoming power cord? They appear to be the only ones with that specific wire color code.
Hope this helps!
Posted on Jul 14, 2010
Maytag quiet series 200 dryer, runs.dries cloths,but timer does not move to time out through its cycles,like cool down and complete or finished.?
It sound like a bad timer motor.check with a local parts store for the replacement part and remove the screws from the top rear housing and you will see how to replace it
Feb 28, 2015 | Maytag Dryers
I have a maytag quiet series 200 gas dryer that will not stay heated
replace the gas valve coils on the top of the gas valve they get weak from the heat of the dryer and can't keep the valve open
Jan 11, 2013 | Dryers
I have a quiet series 200 Maytag dryer. The dryer comes on but the drum does not turn?
Sounds like your belt broke. Here is a video to show you how to replace it if it is broken.
Here is a link to the part.
Nov 30, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag dryer (model no. 3758AYW) makes a loud humming noise...otherwise it works. Vent was disconnected and it still hums continuously when turned on. This is supposedly a "Quiet Series 200".
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This often indicates that the motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Whirlpool LER5636P Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
NEED HELP WITH WIRING
There should be a diagram inside the back panel
Dec 15, 2007 | Maytag MDE3706 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
744 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
