Question about Gateway GM5664 Desktop PC
Trying to hook tv up to computer forced tv enable i have a gateway trying to hdmi connect to samsung flat screen... computer not detecting tv in catalyst(tm) control settings
2 Suggested Answers
SOURCE: I have HDMI port on back of Gateway. I plugged a
Hello, I have a Gateway DX4300,For the HDMI to be detected you need to power on the device it's conncted to
Posted on Dec 11, 2010
How do i connect my gateway zx6970 to tv
Hi
I don't know how helpful I can be but I will try.
Firstly. Are you selecting the correct HDMI input on the TV. I have four on mine, and need to select the correct one for what I want to view.
Secondly, have you got the HDMI outlet selected on the computer, via your graphics card controller, as I suspect that HDMI will not be the default outlet. I would expect automatic detection when connected, but that option may be disabled in the controller.
Cheers
Dec 26, 2014 | Gateway ZX6970 All-In-One Desktop...
Alienware x51 Desktop black screen on tv...
You have to enable HDMI on the TV and the Computer
Jan 30, 2014 | Sylvania Televison & Video
Hdmi input not working
Try right-clicking on your desktop while tv is plugged in and select screen resolution, that should open the properties window that will allow you to activate or change resolutions for the tv or detect it. Make sure that the tv is enabled and if necessary choose to extend your desktop to it.
Jan 16, 2014 | Sylvania LC320SS9 32 in. LCD TV
Hook gateway intel n450 to flat screen television
You'll need a cable that will connect from the computer to the tv. The easiest way is if you get a cable that will have the same type of connection for both the tv and the laptop. Otherwise you will need to have an adapter that will go between the two.
Once you have them connected by a cable then turn the tv on and select the input (source) which in most cases will be PC or Computer or HDMI etc. Boot the laptop and the image should appear on the tv. If not you will have to Press and Hold the FN function key near the bottom left on the keyboard then hit the F1 thru F12 key that toggles the display. The correct F1 thru F12 key to hit will have LCD/CRT on it or it will have the icon of a display.
May 04, 2012 | Gateway Netbook N450
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
I wanted to know if there is a way to hook my Samsung N150 Verizon netbook or notebook to my tv to watch a movie from the laptop
If the netbook has an HDMI port, you can connect it to most flat screen tv's with an HDMI cable. If there is no HDMI port, then you cannot connect it to a tv.
Hope this helps!
Regards,
Joe
Jan 02, 2011 | Samsung Computers & Internet
TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Jun 18, 2009 | Televison & Video
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Connecting my pc to my tv
verify the settings for your monitor are correct. with a video card that supports an HDMI output you should be able to go into your display properties (maybe advanced properties) and either force the TV detection or force the HDMI output to be enabled so it's displaying on your PC and your TV simultaniously. I know with N Vidia GeForce video cards you can do this and with most major brands it should work similarly.
May 17, 2008 | Philips Shielded Serial Cable...
Open Questions:
Gateway GM5664 Desktop PC Logo
61 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
