Question about Maytag Dishwashers
How to remove lower spray arm from a dwu7400abx maytag dishwasher
    Genius:
  • 1,075 Answers
It just pulls out with a gentle tug.adrian,,,
Posted on Jul 14, 2010
  • mygraygirl Nov 07, 2010
    What if it doesn't? Could it be gunked up with something or do I have to keep really tugging?
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Top spray arm doesn't spin
The filters are probably plugged. This will require removing the lower spray arm and cleaning the screens or its possible your not getting enough water in the dishwasher which will cause th upper spray arm to not turn
Feb 10, 2018 | Maytag Dishwashers
How do you remove the bottom spray arm?
Hello
Unplug the dishwasher. If you cannot access the plug, turn off the dishwasher's circuit breaker in the electrical circuit breaker box to stop electrical power to the dishwasher.
Open the dishwasher's door, and pull out the bottom dish rack. Set it aside.
Hold the lower spray arm still with one hand. Turn the retaining nut clockwise with the other hand until it comes free. Pull the spray arm up and off the shaft.
Sep 12, 2011 | Maytag Dishwasher
Dishwasher makes grinding noise when you turn it on
There is something in the shredder plate under the spray arm. To clear this you will need to remove lower spray arm and then using torx driver remove the screws holding the housing together and remove the housing to get to the debris underneath. Good luck and hope this helps.
Mar 03, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
How to remove lower spray assembly in order to clean water filter
There should be a plastic nut holding the spray arm. Remove the plastic nut and the spray arm should release.
Does this help you?
Vic
Jul 23, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
How do you remove the lower spray arm from a maytag mbd4100 dishw
go to managemyhome.com and type in your model # and get your manuals.
May 03, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Quiet Servies 100
Yes remove the arm ,if its the lower arm it un screws,the upper arm snaps on& off.
Jun 03, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Dishwashers Logo
328 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
