Question about Pioneer GMD7500M Car Amp
Amp's blue light is on but does not seem to send power to sub
Amp's blue light is on but does not seem to send power to the subwoofer. Have gain setup to 60% and was listening to music for 3 hours straight in 80 degree heat. What could the problem be.... I checked the ground and it seems fine and the fuses are also ok. Dont know what else to do
  • Pioneer Master
  • 17,130 Answers
It is possible that the set has gone into an error shut off. Please disconnect the power and allow it to cool off. remove the sub woofer connections if the amp does not turn on again. check for any short in the coils. reconnect the sources once again , making sure that the source is coming into the amp. If there is still no output, remove the cover and check if the main amp is shutting off due to any short in the output. You will need to confirm this out as you had run this a little too much in heat. replace the shorted mosfets if confirmed. hope you get this right. Good day
Posted on Jul 14, 2010
How can i get my speakers fixed
It may not be the subs, but the amp could have caused the subs blowing/freezing up. If an amp is clipped it will send to much voltage to the subs, thus blowing the subs. Clipping the amp is when someone sets the gains on the amp to higher than the sub can handle. Find this out before you buy new subs. If not, you may have blown subs again.
Sep 28, 2012 | Alphasonik PSW112C Alpha 100 Series 12"...
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
Can i use my jensen jxp340 amp with my one 800watt 12" 4 ohm subwoofer?
Yes, technically you can, however you will be putting both your sub and your amp at risk. One of the worst things you can do to a sub is underpower it. The easiest way to explain it is n ot giving enough power to the sub leaves it starving for power. The motor structure ends up working too hard to try and move the cone properly and what happens is the sub will usually seize up rather than blowing out in the term you usually hear (ie, I had my system cranked up and I blew my subwoofer).
Secondly, in an attempt to get any real sound out of the under powered sub, you'll probably end up cranking the gain and bass boost on the amp which ends up overworking the amplifier quite a bit and can in turn lead to fried out amp chips, burnt up circuit boards etc.
Thirdly, by maxing the gain bass boost you're going to end sending a lot of distortion through your subwoofer in an attempt to get some decent bass. Distortion kills both subwoofers and speakers alike.
So to answer your question, yes you can hook up your subwoofer to that amp and yes, it will probably play for a while but I wouldn't recommend it. Look for a class d or mono block amp to push your sub as these will give you the most power and best heat dissipation. They are designed to push subwoofers specifically and you will get better sound and longer life out of your equipment. A good rule of thumb is look for an amp within 100-150 watts of both your RMS power handling and your Peak power. Remember, when it doubt, always go a little bigger on the amp side of the spectrum. It's easy to "tune down" an amp by having the gain and bass boost at a lower level (50%, 25% etc), than to turn 'em all the way up just to get some bass and end up prematurely blowing out your sub, amp or even worse, both.
Dec 01, 2010 | Jensen JXP340 Car Audio Amplifier
My sub has all bin wired up proberly the sub works for about 30 secs then the green light goes out and no power to the sub at all
Green light on amp?? Seems like your amp is going into thermal overload. Check your power connections, and make sure there are no shorted wires. Hope this helps.
Apr 21, 2010 | Fusion FEW12PK Car Subwoofer
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Subs not hitting
remote wire turning on amplifier?
Ground for amplifier?
Gain improperly set?
Radio output crossed over above tuning freq. of enclosure?
Just suggestions. Not much info to go by.
Dec 15, 2008 | Jensen BP212 Car Subwoofer
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
Subwoofer seem to be broke
The one sub that you described is gone, there should be no reistance at all when you push on them. It sounds like you got your gains set to high on that amp (maybe the amp is underated for your subs). When you turn up the gain to high your cause your amp to distort and it can get as bad as sending a pure DV current to the sub. That DV current will blow subs because of all the force directed in one direction. If you think about it the amp takes a DC current and turns it into a AC current which creates the frequecy (rate at which it alternates) that alternating current pushes and then pulls on the sub keeping it within its boundries.
Nov 19, 2006 | Eclipse SW9102 Car Subwoofer
Pioneer GMD7500M Car Amp Logo
247 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
