If the dishwasher is connected to a spigot on the waste under the sink, check that the end has been cut off the spigot (on the plumbing not the machine hose) or that end stoppers have been removed. Also, check the hose has not been crushed when installed.
E0 STANDS FOR NO WATER @SUMP PROBE DURING 3 CONC. CYCLES. MY FIRST GUESS WOULD BE THERE IS SOMETHING STUCK IN YOUR DRAIN VALVE ALLOWING ALL THE WATER TO GET PUMPED OUT INSTEAD OF WASHING AND STAYING IN THE TANK. DONT FORGET TO VOTE
first feel around the drain and see if there is something stuck inside the drain. then take a small amount of clorox2 powder and run it through a cycle. after that try jet dry. sometimes there is a grease build up or a lime build up that needs to be removed.
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
ok first of all there is a drain pump and wash motor pump. which one is running?Then tell me what kind of buttons u have.Are the touch buttons or plastic buttons that move
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
