Question about Philips Magnavox TP3285C 32" TV
Horizontal grey lines and tv cuts off by itself after 10 sec
I have a philips magnavox tp3285ci 32". When I turn on, the screen has the grey lines and then the tv cuts off. Help!
  • Shahid Electronics
    Shahid Electronics Jul 14, 2010
    Horizontal IC ????? where it is located in this tv circuit board? If Horizontal IC got bad, why does tv show gray lines before to cut-off? any info about that mr. tv expert.
  • 1,512 Answers
G'Day,
The grey lines you describe, sound like retrace lines. There will be a problem in either the screen voltage drive stages, or possibly power supply regulation causing this. If the set had a "horizontal IC" problem?? you would not get much on the screen at all as the horizontal(flyback) stages would not be operating. You need to be at least scanning to get the lines across the screen you mention. The set is shutting down to prevent any damage occurring. This repair will take a TV tech to solve for you, and as the replacement cost,and age of the set, at least 7-8 years... repairs could be considered uneconomic if costs were to exceed $150. Get a free quote from a repair guy near to you.
regards
robotek
Posted on Aug 04, 2010
  • Philips Master
  • 3,866 Answers
Anyshop would take this under coinsignment as a bad Horizontal IC
"intergrated circuit"
But do not shoot the messenger, its going to need a shop, I would not recommend you opening this unit and risk a fatel shock or Death. Just the flyback transformer alone could kill you. Not to sound harsh but please understand, I do not want fixya to be on the late night news that it gave someone a solution that could have caused injury or death, if your not experienced take it to a shop. You cost if it is a IC witch it sounds like to me your looking $75-$100 parts and labor.
Thanks for your intrest in fixya.com please do rate and leave feedback.
Posted on Jul 13, 2010
Testimonial: "honest info...doesn't get any better than that! Thanks!"
Magnavox ms 3252s431 Bad picture and turns off by itself
Hello, Change horizontal driver buffer transistor's and capacitor's. 7461 7463 transistor's. Caps 2455 2405 near transistor's. Please leave your email address, I will try to find the service manual for you. Best regards, Arpi
Jul 26, 2007 | Philips Magnavox MS3252S 32" TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
My magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
Nov 22, 2008 | Philips Magnavox 20MC4304 20 in....
Magnavox tv
the automatic code is actived.
Nov 09, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox resistor problem
The CRT board is the one that connects to the back of the CRT.
Follow the 200VDC line to locate the burnt resistor, is normally a low value fuse resistor.
Apr 15, 2008 | Philips Magnavox 27MS343S 27" TV
Philips magnavox 32" TS3260C1
Sounds like retrace lines. Leaky caps or worse can cause this.. Are you getting any vertical foldover at the top of the screen?
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
White Screen w/ White Lines, Sound On, Turns off after 2 or 3 secs.
Hi If you mean thin white lines, this is is an indication of a problem in the Horizontal Drive ckt. most likely the Damper Diode has opened or shorted, this would cause the visual symptom and then the set would shut down, unfortunately this is a problem best left to a qualified technician to repair, hope this helps.
Apr 12, 2007 | Philips Magnavox 27MS343S 27" TV
T.v. sound no picture reading err 411021 on screen
It's a long shot, but you could try unplugging the set for about a minute. Philips is among my least favorite sets to repair, and with it being a 25" model it probably wouldn't be worth taking to a repair shop if the power interruption doesn't reset it.
Jan 01, 2007 | Philips TS2575C 25" TV
Philips Magnavox TP3285C 32" TV Logo
380 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
