Question about Sub-Zero Bottom Freezer Refrigerator
Sub zero 511 icemaker not working ..
I had turned down the entire frig. to zero by turning it down with the interior controls while painting the trim ( for rusted appearance). after 3 days, i raised the temp up w the interior controls to resume normal function. apparently, it never goes off w this method..... i believe that the once working icemaker is now frozen. the mechanics are prob. fine. how do i troubleshoot options to get it going?
    President:
  • 2,702 Answers
Well it happens you know?
the control switch thats never been moved for years packs up the moment you try to move it! that was the thermostat control by the way,
its like a volume switch,,,they kind of weld them selfs together,,you just broke the weld! the only way to fix it now is fit a new thermostat
like i sead,,,it happens,,,dont it?
Posted on Jul 13, 2010
Viking Frig ice maker
Depends how old the Viking is?
Older Vikings with icemakers with a arm on the side, simply lift
the arm up until locks.
Newer Vikings with Electronic Controls look for a "slide switch"
mounted on the right side of front interior trim. You will see a
red led light usually blinking on and off near the slide.
Feb 19, 2015 | Viking DFSB483 Side by Side Refrigerator
Paint Chipping
Are you sure that it is the paint and not calcium or nitrate deposits?
Jul 10, 2013 | Sub-Zero 680 / F
Sub Zero model 632 Icemaker shutoff arm stuck in the up position. No water in ice tray. Tried turning frig off for 30 seconds, no luck. Checked water supply, it's good. Metal fill tube not...
The shut off arm is in up position. This is the off position for the ice make. Try pulling the down to the first level this will engage the micro switch to start the ice maker. Also, behind the ice maker is a 4 wire plug remove the plug and see if there were some electrical arcing. But first before removing the ice make plug--Please unplug the refrigerator first before work on the ice maker. stewbison
Aug 20, 2011 | Sub-Zero 632 / S
We have a sub zero refrigerator with the freezer on the bottom. The ice maker stopped working and i am wondering if there is a switch that i might have accidently hit to turn it off
No, Sub Zero does not have an icemaker switch to turn it off and on. How old is your unit? Icemakers can last for 3 years and sometimes they can go out after 18 months.
I believe it's your ice maker. We are factory authorized Sub Zero and can get the correct part out to you right away.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We are at your service from 7 AM until 9 PM CST Mon-Sat and look forward to assisting you with this and all your appliance repair issues.
Nov 06, 2009 | Sub-Zero 650 / O Bottom Freezer...
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Icemaker does not work on subzero 650
My ice maker on the Subzero 650 is up and running again. After checkig the tray and shutoff mechanism thoroughly I checked the display in the fridge aea and noticed a "service icemaker" indicator. I turned the icemaker off and then on again with no change. I then turned the power to the entire refridgerator/freezer unit off, waited ten seconds, and thurned it back on. This apparently must have reset some type of logic because the icemaker immediately began to cycle (ice ejector began to turn slowly) and then I heard the water soelenoid turn on to inject water into the ice trough. It's been 24 hours now and the icemaker tray is filling up nicely. I guess my icemaker just need to be rebooted. The miracles of modern technology. I appreciate the suggestions posted in response to my posting as well as the postings of others with similar issues as well as te corresponding suggestions. All of these together lead me to investigating areas that ultimately lead to resolution. I probably would have called for an expensive repairman if not for this forum. THANKYOU!
Dec 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
279 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
