I have a Toshiba Satellite L300-1AQ and my wireless capability keeps turning off loads at random times even though the switch is turned on. Then when i disconnect from the internet to try and reconnect again it says there are no networks availiable (even though there is). I have to restart my laptop and then go on diagnose problems and each time it says my wireless capability is switched off even though it is switched on!!
colin324
  • 57 Answers
SOURCE: losing internet connection when I try to connect laptop to wireless router
Your cloning the mac address - thats the problem. It should use it's own mac address to connect to the modem. You need to power down the modem, then repower after a minute or so to let it connect to the new mac address. The problem you are seeing is due to network collisions betweenj the desktop and the router with the modem.
Posted on Nov 29, 2007
watz up
  • 6 Answers
SOURCE: netgear dg834gt problem connecting to hp pavilion dv4000
HI
NOTE: The following setup info .is for da PPPoA connection type.(most common in UK).
Its advised to keep da ethernet connected to your laptop untill you configure da wireless on the router, you can disconnect da ethernet cable after the confoguration is over to connect wirelessly.
Try the following: check if your PC is communicating correctly with router. (You might need to restart the computer, after the router is connected to it). On the desktop click on Start and then on Run. In the open box, type cmd.
It will bring up the command prompt window
Type command ipconfig in that window and press the Enter / Return key on the keyboard. It will bring up results similar to the image below.
Note the values of IP Address and Default Gateway in the ipconfig command results. If the IP address is in the range of 169. 254.x.x or 0.0.0.0, then your PC is not communicating to the router. In such a case contact your router vendor for support.
If the IP Address is in the range of 192.168.x.x then the network setup should be ok. Note down the values of IP Address and Default Gateway. Close the command prompt window.
Open Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of a Netgear router it should be 192.168.0.1
It should bring up the logon window similar to the image below. Type the router username and password in the respective text boxes. Refer your product manual for the default Router username and password. In case of most Netgear routers, default username is admin and password is password. Then click on the Login button to continue.
In the next window that appears, click on the setup wizard button
This should bring up the Setup Wizard page similar to the image below. Select Country as UK and Language as English. Under Auto-Detect Connection Type, select No. Then click on Next button.
Basic Settings page will appear. Under Does Your Internet Connection Require A Login?, select Yes.
Configure the following settings in the window:
  • Encapsulation: Set it to PPPoA (PPP over ATM)
  • Login: Type your login name. (in most cases its the primary email address that you get from your ISP)
  • Password: Type you account password. (make sure there are no spelling or case mistakes)
  • Service Name: Leave blank.
  • Idle Timeout: Set to 0.
  • NAT: Select Enable.
Now click on the Apply button. (Please note that it may take up to 5 minutes to apply the new settings)
Then ckick on da wireless settings option.( its on the left pane on the window).
- keep the channel as 11.
- mode can be g&b
Make sure that da option WIRELESS ACCESS POINT is enabaled.
Also check da security options .... I would suggest use WPA-PSK encryption.
make a note of da shared key(network password).
ckick apply and wait till it saves the settings.
Disconnect the ethernet and try connecting to the wireless network with the correct security key.
Hope this helps you.
cheers
SHADAB
Posted on Sep 13, 2008
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite wireless switch doesn't turn on
Ok, if your using Vista, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please and thanks for using Fixya
Posted on Feb 13, 2009
  • 145 Answers
SOURCE: I have Time Warner Cable for internet and Vontage
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Posted on Apr 09, 2009
  • 27 Answers
SOURCE: Computer crashes when turn on Wireless switch
problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Posted on Aug 02, 2009
Toshiba Satellite M45 WinXP keeps dropping wireless internet connection.
Try to do update from Control Panel - Security Center - Automatic update.
Jan 29, 2014 | Toshiba Satellite M45-S331 Notebook
No wireles capability
Is there a sliding switch at the side?
If not try [FN] + [F8] keys.
or Toshiba "configfree" software.
Nov 27, 2013 | Toshiba PSLW1U-00P00S - Satellite Pro...
It will not connect to wireless, it keeps saying turn on wireless communication switch yet there is no switch on the computer. I have been without a computer for almost a week, please help!
@kblossom1280
There's two switch to turn the wireless capability of this laptop:
1. You need to turn ON the physical wireless switch located at the top of the keyboard (see image below)
2 If that doesn't turn the Wireless ON, you need to press the Fn+F8 key (the Fn key is located on the left side of the space bar).
Good luck.
Sep 07, 2011 | Toshiba 14 Satellite M645S4114 Notebook PC
Wifi switch is turned on however, when i try to search for a wireless network i get a message saying that i need to turn on my wireless switch
So I understand that your wifi card doesn't work?If that is correct go to Toshiba site and check their support-from the other computer-of course.If card is dead, you will need usb wifi.
Nov 15, 2010 | Toshiba Satellite Pro L300 Notebook
Is my Toshiba Satellite laptop L450-136, 2.2Ghz wireless or I should buy an adaptor
no need to buy an adaptor as this laptop is wirless,there should be a switch to turn on the wireless capability,also look on the f keys for the wireless logo if you find it then try pressing it while holding down the fn key,or shift
Nov 18, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satellite p25-s5263 boot lockup when wireless switch on.
Try to download and install newest windows drivers for the wireless and check BIOS for wireless settings. Apart from that... stick to Linux? ; )
Nov 06, 2009 | Toshiba Satellite P25-S5263 Notebook
Feb 13, 2009 | Toshiba Satellite M35X-S161 Notebook
My toshiba satellite p200 keeps turning off randomly.
Often this indicates that the battery is nearing its end of life. Even when plug and using the AC adapter/charger, this would occur if the electrical consumption is always at its peak. Noticeable is especially when the built-in WiFi card is in use.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Toshiba Computers & Internet
My wifi switch
there are two..a mechanical one, and a firmware one..check the panel on your satellite pro, to see IF the wireless is illuminated. if not, find the switch on front or side of unit, and turn that on first.
Feb 25, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
