Question about JVC Audio Players & Recorders
How do I replace belt on a JVC turntable model L-L1?
  • 104 Answers
SOURCE: How do you reinstall drive belt for JVC AL A155 model turntable?
http://www.archive.org/details/Turntable_Belt_Installation
archive.org above has a video about how to do it. The general method shown applies to just about any turntable including your JVC
Posted on Feb 10, 2009
  • 3 Answers
SOURCE: I have a JVC L-A11 turntable. I cannot get the
I just had my L-A11 in to 'the needle doctor' (Jerry Raskin's shop in dinkytown, Minneapolis) We had the same problem with the platter.
After pulling (hard) to no effect on the platter - using the holes near the spindle and pushing simultaneously on the spindle. The tech next got out a small hammer, and while pulling on those same holes in the platter, he gave it a sharp 'whack' on the spindle with the hammer, and it came right off (the platter). I would have been too feint of heart to do it, but it worked great.
Posted on Feb 23, 2010
  • 257 Answers
SOURCE: how to replace the belt on jvc l-f130 turntable
You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
Posted on Aug 18, 2010
freetek
  • 5568 Answers
SOURCE: replace belt on a JVC L-A21 turntable auto return
Some years ago, I found only one supplier; now there are several:
Turntable drive belts
Posted on Nov 18, 2010
Mr_Hyd
  • 10 Answers
SOURCE: Need needle and belt for JVC turntable model
Go to the following web site......... http://www.needledoctor.com/ . They normally carry anything which you'll need in stock. I've used there site a few times with GREAT results.... their prices are good, selection is fantastic, and the shipping is lightning fast! Hope this helps! GOOD LUCK!
Posted on May 15, 2011
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
    I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
    Jan 01, 2011 | JVC Audio Players & Recorders
    How to replace the belt on jvc l-f130 turntable
    Nov 22, 2009 | JVC AL A158BK Turntable
    JVC Turntable won't turn, motor works, can't remove platter
    http://www.vinylengine.com/library/jvc/jl-a20.shtml
    Looks like this is a belt drive model.
    http://www.turntablebasics.com/belts/jvc.html
    This site claims to provide installation instructions with belt purchase. Good Luck.
    Jun 20, 2009 | JVC Audio Players & Recorders
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    Feb 10, 2009 | JVC AL A158BK Turntable
    JVC turntable LA10
    The trick is to lift up on the platter (tothat metal on metal feel that you had) while simtaneously "lightly" tapping on the top of the shaft with a hammer. Trust me it will work as just changed my belt.
    Hope that helps.
    Mar 16, 2008 | Audio Players & Recorders
    164 people viewed this question
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
