Question about Garmin GPSMAP 178C Sounder GPS Receiver
My Garmin GPSMAP 178C screen backlight failed
My Garmin GPSMAP 178C screen back light just failed. Have only used it about a dozen times. It has not been impacted, dropped, submerged or damaged in any way. FYI: It is almost impossible to get through to Garmin about this.
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Posted on Sep 15, 2011
Why does my screen blink all the time on my 178c sounder
check your power connection, if that is still good your unit may be dying
Jul 05, 2014 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
GPSMAP 178C Sounder GPS Receiver: My 178C will not stay powered up. I just replaced ...
I had the same problem with mine. It is caused by a crimped wire on the internal harness inside the machine. I opened it up and discovered that when originally put together 3 of the wires from the plug were crimped. One was broken off. The only way to fix it is to open it up, restrip the wires place a piece shrink wrap on before you solder it back and then make the shrink wrap flush with the back of the plug and heat her up. And, Voila... no more intermittent operation. Hope this helps? John
May 18, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin 178c won't find satellites
It would appear that your Garmin has no clue as to where it is on the planet. I think a trip to the owner's manual:
http://www8.garmin.com/manuals/GPSMAP178CSounder_OwnersManual.pdf
might be your best bet to help initialize your unit. The info on how to graphically initialize your Garmin can be found on page 5.
Hope this is helpful.
Good Luck!
May 04, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin 178c turns off on it's own.
Hi
Sounds very much like the wiring plug connections in the back, always overlooked but so important that connections are tight and contacting.
Jul 06, 2009 | Garmin GPSMAP 178C GPS Receiver
Garmin 178C Boots up then shuts off
Check the pins at the connector on the back of your unit. Make sure one of them is not bent or broken off. One of the pins on mine is missing about 1/16" of the tip. My boat repair shop says it's the power lead, but Garmin wants $200 for a generic repair.
Oct 18, 2008 | Garmin GPSMAP 178C GPS Receiver
Dark Screen
almost all LCD use a flourescent lamp, some very new and expensive types use OLED.
Dec 12, 2006 | Garmin GPSMAP 178C GPS Receiver
Garmin GPSMAP 178C Sounder GPS Receiver Logo
1,017 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
