Question about Acer Aspire 5735-6694 Notebook
My computer beeps continuously every time i have it plugged in
  • 942 Answers
Try this suggestion. Turn off your laptop, remove the cables and battery on the pc. Press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop and then turn on the pc. If it still continues to beep with no interruption, it is a problem on the motherboard. I suggest to call Acer and have your computer repaired immediately unless if you know how to reseat the motherboard by tearing down the laptop..
Posted on Jul 13, 2010
    Novelist:
  • 155 Answers
Hello 1. No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
One beep is a normal POST. That means everything is fine.
2. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble. 3. Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. 4. Six, seven and eight beeps.
Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard.
5. Nine beeps mean the BIOS is bad. Replace the motherboard.
6. Ten beeps means the problem is in the CMOS. I hope the list of code would help settle the panic and if it does not then visit a computer doctor. GOODLUCK
My gateway dx4860 ub33p is making 1 long continuous beep at start up not showing anything
Unplug power cable
Hold down the power button for 10 seconds
then remove power cable from the back of the computer and plug it back in.
try plug it directly to another outlet
that long continuous beep is a power issue
if you originally had it plugged into a power protector or multiplug connect it the outlet directly to get better power.
Jun 15, 2014 | HP Compaq dx2300 Microtower - RT950UTABA...
Low battery mess changed it and still continues to beep how do i fix
Power your system down first. Plug in the battery, the panel should beep, then plug in the AC power. If the panel doesn't beep you might have a bad battery. If the panel powers up after the battery then AC power reset your time and the beeping should stop.
May 16, 2014 | GE Security Simon 3 Wireless Home Security...
Gateway laptop wont turn on just beeps continue
How Many Beeps you hear ?
1 Beep Continues > Problem in RAM
2 Beep Continues > Problem in RAM or Mother Board
3 Beep Continues > Problem in Base of RAM is Not Same
4 Beep Continues > Problem in Time System
etc.
i Recomended to you to see at zylone81.indonesianforum.net/forum/ for to know Computer and laptop Problem from Beep sound.
Jan 06, 2012 | Gateway NV5929u PC Notebook
P5KPL-AM speaker beep
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Sadael.
Yes some-times the case/computer chassis does not have an internal BIOS/CMOS beep code speaker built in.
So what you will need to do is go to your local computer store and purchase a mainboard beep code speaker. You may even find it online at your favorite computer store.
The modern speaker is very small compared to the older mainboard beep code speakers.
Your computer will continue to work without the speaker, the beep code speaker is there to help diagnose/troubleshoot problems when they occur.
Take care!
Dec 16, 2011 | ASUS P5KPL-AM SE Motherboard
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Long beep problem when I turned on my computer
Not the right category for computer but a beeping computer on switch on usually means the memory module is not present or not working.
A continuing beep beep beep memory missing.
One long continues beep that stops and the computer then works could be anything normally the PC is looking for something can’t fined it and moves on.
If you are concerned restore the system to a previous time i.e., prior to the beep starting to happen.
Sep 13, 2010 | Home
My computer cannot boot because of long beep
beep code usually means a basic function was unable to start. A basic function might be reading memory, displaying video, or being able to send information to a hard drive. The most common problems that cause beep codes are memory and heat-related failures caused by a build-up of dust in critical cooling areas. Use the beep code tables in this document to help find what hardware component is causing the problem. This might reduce the time required to find the hardware component that needs adjusted, reseated, or replaced. WARNING: HP recommends that these steps be performed only by someone with experience in working on computer hardware. Incorrectly handling sensitive internal components can further damage the computer and can introduce the risk of personal injury. Using the correct environment for working on computers (ESD precautions and tools), use the following steps to isolate and fix the problem:
  1. Turn on the computer.
  2. Listen to the beep code and write it down. Write down the number of beeps before each pause, if the beeps are long, short, high in tone, or low in tone. You can use the other sections in this document to look up the beep code description. The beep code and its description can be used for further Internet research if needed.
  3. Note which fans are spinning, not spinning, or making strange noises. It might be possible to prevent the beep code by setting the fan speed to a higher setting in the BIOS setup utility or by cleaning the cooling fins and vents.
  5. Check the case fan and power cable.
    1. Turn off the computer by holding the power button for five seconds.
    2. Disconnect the power cord and then disconnect all external cords from the computer.
    3. Remove the side panel to open the computer.
    4. If the case fan was not spinning, make sure the case fan power cable is connected to the correct pins on the motherboard. Replace the fan if it was making excessive noise or was not spinning. If you had to plug in or replace the fan, replace the side panel, plug in the power cord and turn on the computer. If the beeps continue, continue to the next step.
  6. Disconnect the power cord and remove the side panel and perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
    1. Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
    2. Remove a memory module. If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module. Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
    3. If the computer has a graphics adapter, remove it. If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step. If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
    4. Remove a PCI card. If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card. Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
    5. Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
    6. At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly. Otherwise, have the computer serviced by HP or by a qualified service center.
Jul 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Acer Aspire 5735-6694 Notebook Logo
1,982 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
