Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
U6439-900 Self Propell on/off switch
Machine will not self propell.Switch will not engage
  • 1,673 Answers
Check the cable to see if it is broke either in the handle or down below, you can see it from the top . If it isn't broke, the part that the cable hooks to (actuator)may be broke. Could be the flat belt, they stretch after awhile and will just slip and drive the transmission or brush roll under load.
Posted on Apr 20, 2008
Simplicity freedom vacuum will not self propell ?
there is a seperate that turns the brush,one for propell..
Dec 13, 2015 | Simplicity Vacuums
Hoover self propell cable needs replacement
Hi there! We recommend taking the cleaner to a Hoover authorized service center to have the self propelled cable repaired or replaced. Follow the link to locate the nearest service center to you. Service Center Locator
Jun 24, 2014 | Hoover Vacuums
Just put handle on windtunnel u6401-9rm and the self propelled switch will not flip into self propel mode. is there an adjustment on the self propel part?
When installing the handle on this machine, you must be sure the on/off switch and the self propel button are both in the OFF position. The actual switch inside must also be OFF, and the metal fitting on the end of the power drive cable should be between the two lines molded into the plastic. After it is re-assembled, it is sometimes necessary to wiggle the handle up and down a bit to engage or disengage the drive button.
Mar 16, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
On my hover U6616-900 the self propell work fine on the med setting on med height carpet, but when I go to low height carpet and height set on med the self propell does not pull the vacuum and it is hard...
This is a typical problem you are describing. I would recommend you change the belts, this will resolve the "hard to push" and most likely resove your issues. based on the s/n given you maching was made on sept 2004.
Oct 24, 2009 | Hoover U6616-900 WindTunnel Bagless...
Self propell feature not working
You can order the lever for the transmission on line for about $16.00. It comes as a cable and lever assembly. I just took the top cover off and replaced the lever without doing the cable. The reason ours broke is because we lifted the vacuum by the handle without the self propel bing turned off, this pulls on the actuator and breaks it.
Oct 28, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
247 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
